Results 1 to 16 of 16
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    thinkin i purchased a chipped car????
    so i here people on here saying how their car is slow stock but mine seem to pull VERY hard. i thinking its already chpped but how do i find out?
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Re: thinkin i purchased a chipped car????
    install a boost gauge
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Or find someone with Vag and do some logging.
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    did you asked the seller?
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Dec 19 2007
    York, PA
    cruise control stalk?
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    or call APR, GIAC, REVO and give them your vin number.
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    Quote Originally Posted by n7plus1 View Post
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Jan 10 2007
    VA
    ^ if you have APR you can change programs via the cruise control stalk. so you can always look up APRs instructions and see if your car responds. if so you have APR. if not you could still have a chip/reflash or could be stock. boost gauge or vag-com is the easiest way to find out. or just take a ride in a stock car or chipped car and compare.
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    see if you can go over 135mph. j/k. or i think if its chipped the rev limiter is increased. may want to try that instead.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    May 01 2008
    Winter
    if you feel turbo boost , it's chipped!
    Feb 19 2008
    NYC/DE
    i have vag-com so how do i log?
    TuRboK1ng
    Feb 19 2008
    NYC/DE
    i have vag-com so how do i log and use the crusie control stalk?
    TuRboK1ng
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    unless the person has the lockout feature.
    Quote Originally Posted by yung turbo View Post
    You want channel 115, "Requested Boost and Actual Boost"
    http://www.audizine.com/forum/showthread.php?t=115366
    http://www.audizine.com/forum/showthread.php?t=115367
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    APR uses the cruse control to switch programs. Turn the key on (without starting the car) and hold the set button on the cruise control arm. If the CEL starts blinking once per second ( program 1) and then twice a second ( program 2) etc..for a maximum of 4 programs.
    Log block 115 and see what you're boosting at (requested and actual).
    Do a 3rd gear pull at WOT until 6k.
    Established Member Two Rings sonic's Avatar
    May 08 2008
    Viper
    ontario canada
    Quote Originally Posted by FourRings80 View Post
    Side note on that, if you have the APR, after you put the key to the on position, click the cruis stalk forward and then hold the button.
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Does the stalk thing work even if you only have on program?
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
