Results 1 to 3 of 3
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    Neuspeed 21mm rear sway
    Anyone here has neuspeed 19 or 21mm rear sway bar on b5 a4? What setting are you using now? Soft, medium, hard?
    I just switched my Soft setting to Medium, I feel that the car is turning one side sharper than the other side
    IG:@steadysupreme
    Pics&Detail
    Veteran Member Four Rings minira's Avatar
    Feb 13 2004
    Jurupa Valley
    Re: Neuspeed 21mm rear sway
    i do, i have mine set on hard. ummm...i've had it only at that setting since installed. would bushings have a play in this problem of yours? i took mine out to the track and the instructor who drove my car stated that i should have mine on full stiff to make it turn in better, at that time i thought i had it at medium.
    77 Porsche 911S
    13 RS5
    14 Porsche Panamera GTS
    16 Tundra PRO
    20 Sequoia PRO
    07 zx6r
    OK, i will try stiff setting. Thank you~
    IG:@steadysupreme
    Pics&Detail
