Results 1 to 12 of 12
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    Help me please timing belt gets loose 00 audi s4 NY
    Hey my name is joe and iv having some issues with my 2000 audi s4 i recently replaced my timing belt. I drove the car about 3000 miles fine it was running really at top notch. recently i heard some chatter inside the timing belt casing so i took it all apart looked and saw my belt loose i took everthing off and replaced the whole kit bec i thought it was a faulty timingbelt kit. I was wondering if the pullys were not on rite torkspecs would this happen? would the belt be getting loose it very weird bec when i loosen the timingbelt the pullys are good and tight. for some reason i put the bar back on and make sure the carts in timing and it is but when its loose i hear like valve tick. but if i put it back again making it tight it goes away i know the motor didnt skip timing! can anyone give me some insight about my problem please i will not keep taking my front end off and tighting my belt. I also purchased 3 hydraulic tentioners, and went and tried all of them and it still has the same problem! Let me add that the week b4 i got a apr chip and threw a o2 code so they put the test pipe application in the ecu then and i have tuned headers and piggies and 2 stock cats no resignator and a high flow muffler i think apr put the test pipe application on my car.
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    Re: Help me please timing belt gets loose 00 audi s4 NY
    i had the exact same thing happen. i had ecs's kit. i bought 4 tensioners and 2 or 3 tensioner rollers, and re-did it about 6 times. on the last try, i bought the pure ms kit, and the belt comparison was insane. the ecs belt was skinnier and shorter, and the pure ms one (oem) was huge and beefy. the other different thing i replaced that last time was the arm that puts tension on the belt from the tensioner. so the only advice i can give is get the pure ms kit and replace the belt and the arm.
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    i see the pure motor sports website, is this kit all oem parts like i would get at the audi dealer and also has anyone used the company fcp grotton timing belt kit for our cars because this kit is faulty and fucked me for a long time now.
    Senior Member Three Rings lowered97a4's Avatar
    Mar 08 2007
    08 turbo busa 09 nissan Gtr
    ct
    i got mine off blau parts no problem yet, ya sounds like some shitty parts to me
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    JHM/AMC trans rebuild
    03 Rs6
    Wagner intercoolers carbon fiber shrouds
    Ecu/Tcu tune
    Cats Removed
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    im getting this new kit tommorow and going to hopefully put a stop to thease faulty kits!
    Senior Member Three Rings BlackS4TT(Josh)'s Avatar
    Jan 24 2006
    Ohio
    Doesn't sound like you've tensioned the belt correctly. You need to pop the cam gear sprockets off (with the cam bar on), apply additional torque to the hydraulic tensioner to tighten the belt, then retighten the cam gear sprockets. The belt will then be tensioned evenly throughout. This step is critical, and should NOT be skipped during belt replacement.
    B7 S4 Avant
    Established Member Two Rings cmagalis's Avatar
    Aug 01 2008
    2000 B5 S4 & 1997 B5 2.8Q A4
    Lakeville Mn
    Its probably the tensioner. All of the rollers etc should be replaced along with the waterpump also. There is no reason even doing the timing belt if you don't replace all the important small bits.
    Veteran Member Four Rings S4 Dan's Avatar
    May 04 2005
    2000 A8, 1992 300zx, 2000 R1
    Connecticut
    im with josh...
    2000 Audi S4 - Rip (Someone elses bad)
    1991 300zx TT - Rip (My Bad)
    1992 300zx - Hope I have better luck
    2000 Audi A8
    Jul 27 2008
    Orlando
    KingofQueenz,
    I think that Blacks4TT is correct, I posted a few vids of what noise I am starting to hear coming from my engine as well. My car runs and idles great, but after driving for a few minutes, I start to hear that Diesel sound. I definitely think it's the timing belt flapping ever so slightly.
    here are some vids to compare your sound too.
    http://www.youtube.com/watch?v=P2X2Y...eature=related
    http://www.youtube.com/watch?v=D5Rbn...eature=related
    http://www.youtube.com/watch?v=NYEmh...eature=related
    I plan on taking it all apart during my upcoming Christmas Vacation,
    Update back if you find out.
    Luis
    Jan 02 2009
    70 chevelle, 01 s4
    portland oregon
    i also did my timing belts about 4,000 miles ago. i hear a funny noise up by the timing belt from time to time but it gose away
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    damn guys ive ruined my motor because of this kit wheir did u get your kits from guys. And also a thing that i noticed is that my hydraulic tensioner wan all the way compressed, i called ecs tuning and they wouldnt even give my money back or do ne thing for me!
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Quote Originally Posted by kingofqueenz788 View Post
    So what youre saying is that your timing belt fell off?? That sucks big time man. Blau parts has really good t-belt kits. I had a ECS t-belt kit on my Passat and no problems for over 3 years now.
