Results 1 to 9 of 9
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    small weekend project
    I'm Planning on changing my leaky valve cover gasket, spark plugs,snub mount and and doing a oil change. I don't consider my self mechanically inclined at all so this is probably as far as i will ever go when doing work on the s myself. I was wondering if anyone has any advice for a novice like myself when doing the gasket,plugs and snub mount?
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    Re: small weekend project
    Make sure you have all the parts on hand, get the right tools, take your time... if you rush you will probably FFFF something else up... Read all the DIY's on those parts you want to change and make sure you confident enough to do the job.. also get a bentley manual if you dont already have one...
    Jan 29 2007
    08 S4 00 S4
    MD
    This might help for the VC gaskets
    http://www.audiworld.com/tech/eng52.shtml
    Spark plugs aren't that hard, you have to remove a few things to get the coil packs out, but other than that, it's pretty straight forward
    May 31 2008
    New York
    is the silicone absolutely necessary?>
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    Quote Originally Posted by s42k5b View Post
    YES! Why skimp it's only a couple dollars extra.
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    It is not to bad teh work you need done, get a friend to help out , it is nice to have an extra set of hands to hold up things and hand you tools, also Audiworld has a few good tech articals to guild you. Also search s4biturbo.com for help as well, have fun
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    do your cam tensioner seals while you are doing the vc gaskets! you need a special tool to take the tension off the cam chain also.
    May 31 2008
    New York
    Quote Originally Posted by infinkc View Post
    might be getting in over my head with that
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    It is very necessary and if you don't do a good job of sealing up the corners you will have valve covers that leak oil on the manifolds. Trust me I know.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
