Results 1 to 34 of 34
    Veteran Member Three Rings rpmfoundation's Avatar
    Aug 25 2008
    2012 Toyota Highlander Hybrid Limited (wtf)
    Hollywood Hills, CA
    Rub Rub Rub your... H&R & 245's??
    Here's thing, I've been doing some massive searching for the last 3 days trying to find whether or not 245/35/19's (Vredestein Sessanta's ) will rub 2008 A4 Quattro on H&R springs.. What I've found was a LOT of conflicting information.
    Some say, "no problems at all" some say "don't even think about it" so which is it??? All tires are made differently, some run wide & some don't, so if you have a 245/35/19 with a drop (similar to H&R springs ) & have no problems.. or LOTS of problems would you please post up the specs of your tires and a drop.
    I need to decide between 235/35/19 and 245/35/19's by end of day tomorrow.
    BTW I am getting 19x8.5 wheels w. 35 offset...
    It's an expensive mistake to make so I hope to get some knowledgeable feedback!
    Thanks for all the help!
    my car is still on AZ... someone else is just driving it (BMO).
    Veteran Member Four Rings nadroj81's Avatar
    Feb 12 2004
    Albany
    Re: Rub Rub Rub your... 245's?? or 245's?!!
    all rims are made differently. Offset before tire size.
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    tires brands are different too. i had toyo's on my b6 usp rims with 10 & 12mm spacers and adjusted my coils perfectly to 25" with no rubbing. then i got nitto's same size and rubbed often.
    Veteran Member Four Rings harryd14's Avatar
    Jun 30 2008
    Atlanta, Ga / Norwich, England
    worse come to worse go with the smaller size for safety
    A4 2.0Tq 6spd - Dolphin Grey
    AWE Exhaust - V708 18x8.5 - Dynavin Navi - Carbonio CAI - Blacked Out Grill - Retrofit Bi-Xenons - Passport SRX
    Smoked Reflectors - 7500k Fogs - LED city lights - CF rear lip spoiler - Tint
    Aug 25 2008
    Hollywood Hills, CA
    Quote Originally Posted by nadroj81 View Post
    Aug 25 2008
    Hollywood Hills, CA
    Quote Originally Posted by harryd14 View Post
    problem with that is that i dont want my tire to stretch.. trying to get maximum amount of rubber with a level sidewall height.. if you get a tire too small it pulls the sides making the height of the rubber (overall diameter ) lower.. - something that i am also trying to avoid.
    Dec 27 2005
    Ft lauderdale
    most people say to go with 235's to avoid rubbing but i see your dilema, i'm not a fan of the stretched look either. i'd prob go 235's to be safe. i'd rather have the option to lower it to my liking
    Feb 12 2004
    Albany
    Quote Originally Posted by rpmfoundation View Post
    side wall on a 245 will be higher than a 235
    Aug 25 2008
    Hollywood Hills, CA
    on a stock wheel 18x8 ti - tire size is 235/40/18 new wheel is 18x8.5 so its wider.. hence my belief that the tire should be wider.. to accommodate the new rim width.. and thats where i ran into problems, some say stick with OEM width due to potential rubbing and others recommend wider stating that there is no rubbing whatsoever..
    Dec 27 2005
    Ft lauderdale
    btw what rims are you getting?
    Aug 25 2008
    Hollywood Hills, CA
    Quote Originally Posted by Johnnie View Post
    i was hoping to kind of keep it on a DL lol -
    v710's in Gunmetal..and to those who are about to post that VMR does not have GM as an option - that is correct, custom powdercoat.
    DUH! an Audi
    los angeles, CA
    I am running 245/40/18 and had rubbing problems, with 5 and 15mm spacers, took off and it worked like a charm!
    edit: rubbing only happened up steep drive ways, not when people were in the car
    Senior Member Three Rings toothysaw2's Avatar
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    not that this is much help, but i run 18x8 +35 offset with 245 and rub, but only with 3 or more people in the car for the most part and only on bigger dips.
    good luck!
    2010 S5: Sprint Blue, 6MT, Premium Plus
    mods: 35% pinnacle tint, hoen xenonmatch fog, hoen license plate lights, rs4 pedals, vag-com, black-out grille and rear valence
    DUH! an Audi
    los angeles, CA
    on a side note, 245 or 235 will not rub if you are on stock suspension...it all depends on how low your car is!
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    From what I understand 235 is plenty of rubber for 8.5" wheels. Even VMR and tirerack recommend 235s.
    I had the same dilemma but I wanted the 245s for the more aggressive look. I played it safe and went with the 235s and I have no issues whatsoever.
    Dec 27 2005
    Ft lauderdale
    that's why i asked. i remember seeing your posts on the v710 threads. i am still considering getting them now too and powdercoating them matte black. the cheapest i've seen here is 125 each where others on the nets been paying 75 so i don't wanna over pay 200 when vmr says they'll come out with them in matte black in a few months. man, decisions decisions. definitely post up pics when you get it done i'm very interested in seeing our ibis titaniums with gunmetal v710s.
    here's what the v710's look like it matte
    Veteran Member Three Rings jstahmann's Avatar
    Feb 21 2005
    2008 RS4 - Imola/Titanium
    Utah, USA
    Ran 255/35 18s on 18x8.5 ET35 wheels with absolutely no rubbing. Ran 265/35 19s on 19x8.5 ET37 wheels with only minor rubbing in the rear when 4 were in the car.
    In both cases the car was lowered using Stasis SL COs.
    255/35 18s at stock height. Even lowered (no pics) had no rubbing. Sorry - it's a 3 year old picture...
    265/30 19s
    FWIW - 235/40 18s on 18x8.5 ET35 SSR Comps. Again, no rubbing.
    John
    Piggie Pipes|Flowmaster 40s|Stasis SLs (800/1200)|Hotchkis Sways F&R|Suede Euro Steering Wheel|Apikol Rear Diff Mount|034 Track Transmission Mount|SilverRS4 PnP Intake|JHM IM Spacers|Status Ring Alcantara Seats|Euro Tails|Rotiform Forged SNA 19x10|285/30/19s|Bonneville 130 & 150 MPH Clubs
    RS4 REGISTRY
    Aug 25 2008
    Hollywood Hills, CA
    lol yeah youre pretty famous here as well..lol.. i've just sold my OG Ti's X_X
    now i am trying to give my car an "appropriate" Ti Package wheels.. RS4's are great, but i see them everywhere.. I am actually doing a photo shoot in Downtown LA with about a dozen exotics ( Aston DBS, R34 BlackBird, TVR etc.. ) so i couldnt just show up with something.. same? - i will post up pics most definitely!
    but meanwhile back to the tire search for me :( grr
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I have 245/30/20s and even though I do have a 30 as apposed to a 35mm sidewall I think the 245 should work fine. I am lowered pretty far on stasis coils and I don' have rubbing. 235/35/19s are recommended for 19" wheels so there really isn't a great reason to go to 245s but I guess for looks and some more rubber.
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    235/35/19 on a 19x8.5 wheel with ET32
    NO RUB/NO STRETCH
    Aug 25 2008
    Hollywood Hills, CA
    [QUOTE=MOFSTEEL;2919607]235/35/19 on a 19x8.5 wheel with ET32
    NO RUB/NO STRETCH
    I keep using your car as a reference.. there's a bit of a stretch on your tire..
    as oppose to this flush fitment.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    what size are the v710s in those pics?
    Aug 25 2008
    Hollywood Hills, CA
    Quote Originally Posted by nsmith12 View Post
    19's 8.5 ( and the guy has 245/35/19 )
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    well then get the 245s, its obviously what you want and others have stated that you won't rub, especially if you are on springs and not coils (non racing springs that is)
    Aug 25 2008
    Hollywood Hills, CA
    This is what will happen to my car - if can finally get the damn tire size!!
    this is the original picture showing the drop ( H&R Springs ) - hopefully the owner doesnt mind me CHOPPING IT..
    Keep in mind - currently i have stock sport suspension , but i will be putting H&R springs on the car. which will drop it.. and unlike coils i cant adjust it. - so tire size has to be good since the get go.
    Veteran Member Four Rings Six Speed Turbo's Avatar
    Feb 09 2007
    Hopes, Dreams, Tools, Car Parts
    Killeen, TX
    Well good luck in any case.
    2016 S3 Prestige - Glacier White Metallic, APR Stage 3+, APR TCU upgrade, APR CAI, APR FMIC, APR Catchcan, APR Lowering Springs, P3 Guage
    YouTube Channel https://www.youtube.com/channel/UC88...LbgXXvRHPvW3Xw <---SUBSCRIBE
    Aug 25 2008
    Hollywood Hills, CA
    H&R Sport Springs// i dont think they have racing springs for our App.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I know, that was my point- they won't rub! Just get a properly alignment and you'll be set
    Dec 27 2005
    Ft lauderdale
    if you're only getting h&r springs.. then you should be fine with 245's. 235's are generally recommended by people with coils that have lower drops than what springs offer.
    Aug 25 2008
    Hollywood Hills, CA
    its morning.. lol sorry.. not much makes sense nor registers.. need more cofffeeeee.....
    Aug 25 2008
    Hollywood Hills, CA
    thank you sir, much appreciate it
    ill get it , if it rubs - ill just come back looking for people hahah
    Dec 27 2005
    Ft lauderdale
    cool, you will be the guinea pig for real though i think you should be fine but it's moreso what brand tires you get hence my first quote and the reason why you hear mixed answers...
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Re: Rub Rub Rub your... H&R & 245's??
    A little bit of stretch looks bette than a flush sidewall imo.
    Aug 25 2008
    Hollywood Hills, CA
    Quote Originally Posted by 4Rings3Liters View Post
    excepttttt.. when height of rubber goes down and chances of rim getting messed up is a lot.. form and function not just "looks" IMO though.. - i guess i grew out of my drifter ( stretch my tires on 10.5 W rims ) phase lol
