Results 1 to 27 of 27
    Senior Member Two Rings hiprings's Avatar
    Mar 02 2008
    2000 A4 2.8L v6 Quattro
    K.O.P. ,Pa
    misfiring problems
    i had a local shop take a look at my car, as it sounds like its diesel.
    they plugged it in and found one cylinder is misfiring and theres a random misfire somewhere. and an oxygen sensor is bad.
    i changed my plugs and wires. next step is the coil pack.
    think this will solve the problem? or might it be something more difficult to fix?
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: misfiring problems
    Swap the coil pack on the misfiring cylinder with a good one... if the misfire follows the coil pack then replace it.
    Mar 02 2008
    K.O.P. ,Pa
    i dont have individual coils.
    its a 30V V6 so its just a single pack.
    Mar 02 2008
    K.O.P. ,Pa
    well, replaced the coil pack.
    $207 later, still sounds like its misfiring.
    i dunno what else to do now
    Established Member Two Rings FknChizA4's Avatar
    May 19 2008
    Audi A4 B5 1.8t
    Pasadena,CA
    lol me and u got the same problem bro. i changed my plugs coil pack, close 2 dropping 1K now.. let me save u some money and tell u to check ur igniter module, dats what the mechanic told me to do. its the reason the car has sudden misfires and makes my car sound like a diesel, pluse it shakes and is embarrassing to drive around, pluse my cars hp goes down when it starts acting up. its like it goes in and out. one min im struggling 2 reach 45 mph and when it kicks back in 2 shape my car pulls out of nowhere its really annoying. but yah check it out get at me to see if u get that fixed.. il let u know how it goes
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by hiprings View Post
    as long as you installed all the plug wires and such correctly your ignition source isn't the issue. Obviously check for spark at the misfiring cylinder though.
    You need fuel, air and heat/spark to cause combustion, have you checked compression of the faulty cylinder? Otherwise swap fuel injectors or at least make sure that fuel injector is receiving a signal from the ECM.
    Quote Originally Posted by FknChizA4 View Post
    The 30V V6's should have their ICM built into the coil pack assembly(IIRC), he changed that already. 1.8T and 2.7T's have the igniter/ICM on top of the air box.
    Mar 02 2008
    K.O.P. ,Pa
    finally an answer on the icm.
    i'm going to do the compression test this week, gotta find someone who's got the tool.
    i have the same exact problems as FknChizA4.
    sounds like diesel, shakes, and it just sucks to be the kid with the audi, and have it not run right. lol
    May 19 2008
    Audi A4 B5 1.8t
    Pasadena,CA
    k. i got it tested and changed my plugs, also coil packs, they run the air pressure test on all 4 cylinders n code says cylinder number 2 is the prob. so we looked at the ignition module which sits on top of my intake, and if we wiggle it just right the car will go from diesel to normal ... seems like one of my wires might be fucked up some where down the line, kinda like an old charger that u gota hold in a wierd way just to be able to charge ur phone datz how my car acts... i looked up igniter module and it says that it is the reason for sudden misfires and makes it look like ur plugs and coil pack might have gone bad.. so do u still think that might be my prob ??? P.S hipring have u tried wiggiling the IG module c if ur car goes from diesel 2 normal??
    Mar 02 2008
    K.O.P. ,Pa
    coil pack=fixed misfire.
    still sounds diesel but my car's still throwing codes for bad o2 sensor and secondary air injection somethin somethin...
    but i need this hose and a new o2 sensor and we'll see what happens...
    Aug 11 2008
    sehg
    i had the same problem with my 98 a4 2.8q tiptronic back in august, as cylinders 4 and 6 both misfired due to cracked lines and had to have both of those replaced. the bucking was caused by that and thus as you both described, for the car to shake a lot, and it not being responsive at times.
    May 19 2008
    Audi A4 B5 1.8t
    Pasadena,CA
    yah im actually going to change the whole wireing
    May 19 2008
    Audi A4 B5 1.8t
    Pasadena,CA
    ok guys so i changed my ingnition module and it fixed my diesel problem... and misfireing .. u need a bosh Ignition module i got it for 150
    Registered Member Two Rings B5_S-LINE98's Avatar
    Aug 28 2008
    98 a4 2.8Q, 05 infinity Q45
    rockville, MD
    where did you get it from. is yours a 1.8t or a 2.8Q??
    Mar 02 2008
    K.O.P. ,Pa
    Quote Originally Posted by B5_S-LINE98 View Post
    he's got a 1.8t
    at least his profile says so
    Dec 30 2007
    wilmington nc
    Ok so this ICM can someone show me a picture of it? Also hiprings does your car backfire through the exhuast when it bucks and spits?
    Mar 02 2008
    K.O.P. ,Pa
    do you have a 2.8?
    and the misfire is gone, so i couldt tell ya about backfiring...
    Dec 30 2007
    wilmington nc
    do you have a 2.8?
    Yes, DID it backfire through the exhaust?
    Mar 02 2008
    K.O.P. ,Pa
    i don't recall any backfiring...just some sputtering.
    and i looked into it and there is no ICM on the 2.8
    Quote Originally Posted by djwimbo View Post
    Dec 30 2007
    wilmington nc
    Cool thanks man nevermind this isnt going anywhere...
    Mar 02 2008
    K.O.P. ,Pa
    am i just not getting something here?
    Dec 30 2007
    wilmington nc
    No it just seems to me like im having a different problem than you bc I believe my coil is still good. Im pretty sure its my plug wires... Just kinda relucatant to drop 150 on wires and then that solve the problem....Just lookin for insight cause im stumped....
    Mar 02 2008
    K.O.P. ,Pa
    well, if it makes you feel any better, i dropped about $400 total to figured out this stupid problem.
    $200 on the coil
    $160 on wires
    $40 on plugs
    im no mechanic, so im really not a huge help.
    Dec 30 2007
    wilmington nc
    $200 on the coil
    $160 on wires
    $40 on plugs
    Haha thanks man no problem... Hopefully I can get this figured out without dropping that much, but hey, at least those parts are new on your car now right?
    Mar 02 2008
    K.O.P. ,Pa
    oh yeah, i figure once everything breaks and is replaced, what can go wrong?
    Senior Member Three Rings TverRus69's Avatar
    Sep 02 2008
    98.5 2.8 A4 QM
    NYC, Penn State, Tver Russia
    Im having the same problem. It started about 2 weeks ago. Car sputters and backfires at low rpm under load (usually in 2nd or 3rd) and if i floor the gas i get the flashing CEL (as expected) and jerky acceleration. Hiprings how long did it take you to change the coilpacks? Where exactly is it located? I really dont want to be dropping 150 on new coils... Why couldn't i have a 1.8 and swap the one thats bad...
    May 19 2008
    Audi A4 B5 1.8t
    Pasadena,CA
    i got my ignition module off this VW AN AUDI repair only... i got a 1.8t
    May 19 2008
    Audi A4 B5 1.8t
    Pasadena,CA
    p.s it has to be the easiest thing to do...
    <a href=" http://www.shokan.com/catalog/images/hamburg%20tek.JPG
    " border="0" /></a>>
