Results 1 to 6 of 6
    Senior Member Two Rings BigMig09's Avatar
    Apr 01 2008
    San Jose, CA
    Suspension Problem?
    I've been driving on my my car for a day now. We installed the H&R bilstein combo at the local meet yesterday. The problem is that it feels and sounds like I am bottoming out WAY to easily. There is a loud cluncking noise (front only) were the shock begins to depress and then all of a sudden just hit something solid. It feels a bit mushy and bouncy over any series of bumps on the freeway. The back feels totally solid but the front is worrying me. Anybody have any idea what this could be? or how to check for a problem? Thanks in advance.
    Mar 27 2005
    The Cold North
    Re: Suspension Problem?
    did you use the oem sport bumpstops? or the oem non-sport bumpstops? If you used the later you need to remove them and install the sport length bumpstops.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Senior Member Two Rings inaforest's Avatar
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    yeah it sounds like your suspension is binding.
    Definitely replace your bump stops with the sport length and see if that fixes it.
    Nov 13 2007
    02 A4 3.0QM, 84 Rabbit GTI
    Gaithersburg, MD
    You can also cut an inch or so off of the stock bump stops.
    Apr 01 2008
    San Jose, CA
    alright guys thanks so much. do you know where i can buy the sport length bump stops?
    Mar 27 2005
    The Cold North
    Quote Originally Posted by BigMig09 View Post
    The dealer is usually a good source for OEM parts. You can also check Purems.com or ECS tuning. I prefer PureMS (mike & his team are great) since ECS never could ship an order to me with the correct parts.
    2020 Chevy AEV ZR2
