Results 1 to 8 of 8
    Active Member Two Rings sotirakis's Avatar
    Feb 04 2008
    philadelphia
    b6 front bumper removal
    alright, now i've been searching for a while and i can't find how to remove the bumper of a b6 s4. i've seen b7's and b5's. i tried winging it but it seems like there's something holding it on. removed all the screws in the wheelwell, the 3 10mm nuts conecting it to the fender and the one above the fog lights. i'm trying to do one side at a time so i can remove the headlights. wanna do the cc mod. also, is there anything else holding in the headlights besides the 2 t30 torx screws? cause it seems pretty loose but doesn't come forward at all. any help appreciated. if anyone has a complete bumper removal that would be awsome cause i was also gonna install a snub mount i've had sitting in my garage for 6 months.
    Senior Member Two Rings NYCS4Avant's Avatar
    Apr 23 2008
    B6 S4 Thunder Wagon
    B6 S4 Avant: Nogaro / JHM Tuned/ Piggied / Milltek Non-Res / JHM SS Trio / Hardwired V1 / SS Brake Lines / CC Mod / Stern Snub / LED License Plate / 18" TSW Vengeance / 20% Tint / DIY Blackout Grill / Black Window Trim / Thule Bike-Ski-Fishing Pole Rack / Full Timing Chain at 68k oh wel...
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    Re: b6 front bumper removal
    a4mods.com is ur friend...and there are two torx up top, and another two on the bottom to lossen the headlights...
    another stereotypical Audi
    Feb 04 2008
    philadelphia
    Quote Originally Posted by a4wd View Post
    where are the bottom 2 torx screws? guess this is what's holding me up with removing the headlights. everything else i've done. removed wheel well screws, the 10mm nuts, loosened the bumper support and the screw next to it. it still feels like there is something holding it on right where the light washer is. could that be the 2 bolts holding on the light? do you know if there is a pic anywhere that i could see where they are?
    Veteran Member Three Rings Bpitz15's Avatar
    May 07 2008
    Hartford County, CT
    i got both sides popped off and the screws loosened in the fog grill area... center of the bumper still wont budge.... any tips???
    Items for sale PM me for details:
    A6/Allroad 4.2 V8 top end
    May 07 2008
    Hartford County, CT
    got it! just had to loosen the two screws in between the fog grilles far past my liking
    Quote Originally Posted by sotirakis View Post
    Pictures
    Follow that link and you will see pics as to where the two hidden torx screws are.
    Senior Member Four Rings Bravest NY S4's Avatar
    Jan 18 2009
    BKNY
    Go to www.audidiy.com it'll show you the whole snub-mount procedure...
