Results 1 to 4 of 4
    Senior Member Three Rings Silver Bullitt's Avatar
    Aug 01 2008
    is really messy.
    Airbag Module = Radio Pull?
    Hey I just need quick confirmation.
    Is it 100% absolutely necessary to pull the radio to get to the airbag control module?
    Or is it possible to get to the module without actually disconnecting the radio (ie can you pull it but leave the cables connected so the radio does not reset)"?
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    Re: Airbag Module = Radio Pull?
    i think you need to pull radio. unless you can pull all the shift sorround, pull the HVAC and have room to get your hands in there with the proper socket wrenches to remove it. i would just pull radio and HVAC to have room to work around. you dont want to damage the airbag control module for laziness. those are VERY $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
    Aug 01 2008
    is really messy.
    That is what I thought,
    Reason I ask is because I had someone work on it but he told me that when he compared the numbers of the part he ordered and the numbers off of my control module that they did not match. He said that I have some different airbag option. But when I picked up the car the radio worked. I am the only one with the code...it is not in the car. So I am thinking that he did not really pull my module.
    Oct 05 2005
    richmond va
    I didnt have to reset the radio when i did my airbag module, Im pritty shure i unpluged all connectors from the radio and it didnt need to recode it.
    01.5 s4 built bottom with pauter rods , BW rs6 turbos , MTM manifolds , ER intercoolers , 044 fuel pump, EV14 injectors , 90mm maf , vast tune for now ,
    X1 intake , ported intake manifold , ASP 3inch down pipes and true duel cat back .
