Results 1 to 3 of 3
Thread: DV gone bad?
    Veteran Member Three Rings discontained's Avatar
    Jul 09 2007
    '01 A4 1.8t
    GA
    DV gone bad?
    Well im k04 chipped GIAC. Tip tronic blah blah.. my DV sounds like a BOV on low boost but up higher boost (17-20lbs) it sounds normal. Could that be flutter or the wastegate going bad? It drives and pulls normal. The wierd thing is that it only does it from 5-13lbs, anything higher its fine.
    thx
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    Re: DV gone bad?
    May be the sound of the engine drowing out the sound of the air being recirculated back into the intake, if u got an aftermarket it'll be very noticable at low RPM's especially with a stock exhaust as the engine is very quiet. Floored the engine is producing a symphony of sounds.. Chances are u would feel the DV goin bad either as hesitation, or lack of power.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: DV gone bad?
    Mine does EXACTLY the same. I took mine out and checked it and its all good.
    IF you really wanna check the DV, take it out, put your finger ontop of the top hole/nipple, and push the piston up towards your finger. If the piston slowly comes back down or holds there, then your DV is good.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
