Results 1 to 6 of 6
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    ok i admit im lazy, where is the best writeup for an engine pull?
    need to pull my engine out, just want to read up.
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Re: ok i admit im lazy, where is the best writeup for an engine pull?
    search for the jebels write up. you cant be that lazy
    2010 Brilliant Black/Magma Red S4
    Feb 14 2004
    S Ã C, CÃ*
    Quote Originally Posted by espo4442 View Post
    Ok found it http://www.daftsgarage.com/Stage_3_swap_writeup.doc
    thanks!
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    the best writeups are
    mike2ks4's motor pull notes
    and the most comprehensive with pictures is the carolinaeuros.com writeup
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    Quote Originally Posted by DxC View Post
    That's the one I used. If you need more details than that, you shouldn't be pulling the engine yourself.
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Dec 06 2007
    Calgary, AB, Canada
    You guys should compare my writeup with Mike2kS4's sometime...
