Results 1 to 17 of 17
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    First Time Painting
    So after looking at the hood of my car the other day and noticing a few sizeable chips (thanks to colorado department of transportation putting gravel down in the winter) and some scratches, that rather than trying to patch these up, i might try an entire repaint.
    What are the odds that i could get this right the first time? Any tips, tricks that might help?
    -Matt
    FCDT Member #1
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Re: First Time Painting
    No use in painting... Sorry to tell you. But they'll reappear the week after. Rock chips, just something we all have to deal with if it's your daily driver
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Its all in the prep work
    -Sami-
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    You should'nt try your first paint job on an A4... IMO. For approx- the same price of the stuff you'll need,a paint shop will make a 1000X better job than you without the knowledge and equipment...
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Senior Member Two Rings Audituning02's Avatar
    May 13 2008
    2002 A4 1.8T 5QM 00 Rover Discovery 2
    Maine
    To get all the chips out the hood will need to be stripped completely, chips filled, sanded and primed. A decent repair shop should quote you around $300. If you paint it without getting all the chips out it will look like you have a bunch of Fish eyes in your final paint job thus looking worse than before. Alot of good DIY projects out there but this aint one of em'
    Audituning02
    Magnaflow : TP : tt 225 DV : Color Matched Lowers :
    Pearl Black Roof : USP Front : RS6 19s : Sport Suspension : Smoked Lamps : Dice Link : Black Out Grilles : 35% Tint : Rear Lip Spoiler : ZiZa Yellow Fogs : B6 S4 Front Brake's
    Deactivated Three Rings
    Apr 11 2008
    Sort of have to agree with everyone here. I thought about doing this for a while, but decided against it. VW/Audi paint is nothing you want to 'learn' on. And if it's black.. you'll never get the exact match. Trust me.. my brother went to school for autobody restoration and schooled me on this.
    Probably better off trying to load up a ton of wax on it or repainting it completely
    Jul 30 2008
    Downtown Denver, CO
    Well my idea was to just give it a shot and see how it goes. If it turned out poorly, then i'd have it professionally done. My biggest worry was just the paint matching.
    -Matt
    FCDT Member #1
    May 13 2008
    Maine
    Is it just black?? If you still want to try it call your local NAPA and give them the paint code and they can mix any amount for you. If the chips really bother you the best thing you can do is get it fixed for a few hundred bucks and then put that clear protector across your hood so it doesnt happen again, if your not planning on going that far I wouldnt do it at all otherwise its just money and time down the tube
    Audituning02
    Veteran Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    I don't know what your plan is on getting the paint. At the body shop when they are about to paint, the computer program spits out a formula to mix. when you add it, its on scale that way you know when to stop for each additive. I know for other colors, you have to blend in order to match the original paint. But on black as long as you mix right to specs. it should be fairly close. Paint booth makes a difference as well.
    May 13 2008
    Maine
    OHH Yeah another idea ! Just slather on the black wax and it'll fill in those rock chips at least temporarily.
    Audituning02
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by mdzaudi View Post
    You see paint is NOT cheap. Plus buying the proper equipment is expensive also.
    To be perfectly honest, I would be absolutely amazed if you did a proper/legit job, but on that same not I still say you DIY. That is the ONLY way to learn.
    Go for it...i know that when i have my own space, I will definitely be respraying my car.
    Like I sais, it is ALL in the prep work. Its something like 10 hours prep for 1 hour painting...something like that
    Good luck
    -Sami-
    Senior Member Three Rings 03CrysBlueB6's Avatar
    May 12 2008
    washington
    what i did was look on your local classifieds.. liek craigslist.. and search "bumper" if thats the part your doing.. i practiced on this.. the bunper was 20 bucks off of a civic. so i practiced and if i didnt get the right.. i was strip the paint and try again.. it beats having to spend 10k on a new bumper!! haha
    B5 A4 - silver [gone]
    B6 a4 - Crystal Blue [current]
    FS: B6 A4 sport struts with about 30k on them
    WTB: S4 or USP front
    Door Blades
    Rear Lip Spoiler
    USP or other Rear
    Jul 30 2008
    Downtown Denver, CO
    Well i have the majority of the equipment so i think my expenses would be rather minor aside from the paint. I can't imagine the paint for a basic black would be that expensive but DO correct me if i'm wrong.
    -Matt
    FCDT Member #1
    May 01 2008
    Winter
    Ok I see you really want to do the job!!
    So you'll need:
    sanding paper 120 grit to 1500 grit
    orbital sander
    sanding blocks
    air compressor with air filter
    bondo filler & glaze
    zinc primer
    high build primer
    base coat paint (color)
    flex additive
    plastic primer
    clear coat
    mixing pot
    was and grease remover
    base coat reducer
    paint thinner
    HVLP gun
    water
    polisher
    buffing compound 2-3 step kit
    Good luck!!
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    here is the first painting thing I did... i have these parts on my car today, and I think they came out very good.
    the shop didnt give me the best clearcoat... and they only admitted it after I applied it and called them.. be sure not to cheap out on the paint... get good quality stuff
    http://www.a4mods.com/index.php?page...ges/paint.html
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    May 13 2008
    Maine
    Also one of the major elements you are missing is that of drying/curing the paint. A paint booth at a body shop bakes at approx. 120 to 140 Degrees and this is what allows the paint to lay down properly and gives you a smooth clean finish. Some shops use large heat lamps for quick drying of primer and smaller repaired panels these also cost several thousand dollars. I always applaud the efforts and initiative of the DIY'er because I myself take pride in my own personal work and of course I like to save a buck if I can..who doesn't?!?
    Audituning02
    Aug 26 2005
    Without prior experience and lots of professional equipment, plus a proper paint booth, the chances of an error free paint job are less than zero.
