Results 1 to 2 of 2
    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T 6MT Modded. Allroad 2.7T 6MT.
    LI,NY
    Can someone cross reference some part #s for me?
    Basically, I am trying to find out if the B7 S4 rear brake conversion intended for the B5 S4 (300mm rotors with adapters using B5 S4 calipers) will fit on my C5 A6. Now I know my front brake setup is exactly the same as the B5, but the rear setup is different. So what I am hoping is that the hubs & whatever else are the same so that the adapters & S4 calipers will still bolt up & align with the 300mm rotors...
    So I need someone to cross reference part #'s of the rear hubs & anything else that will be needed for the kit to work.. Thanks to anyone that can help out on this. Or if maybe someone already knows it will fit..
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me, full weight, street tires, 29+lb wheels.
    Ran an 11.8 @ 119 at MIR - Sept 2008. FIRST A6 IN THE 11's!
    Also 04 Touareg 4.2 89k with 22x10s
    May 04 2007
    LI,NY
    Re: Can someone cross reference some part #s for me?
    Got a little update that shows more promise for compatibility. I crossed reference rear pad model #s from the B5 S4 to the C5 A6 on ECSTuning's site and they are the same for every brand.
    The rear rotors are very different. I was looking at a friend's S4 rears and they are 2 layer, vented vs 1 layer solid. And they are also not set back as far behind the wheel..
    So ultimately, it comes down to if the calipers are where the difference is or if its where they bolt to thats the difference.. Hopefully someone can help shed light on this...
