Results 1 to 8 of 8
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    ECU compatability
    i tried searching and couldnt find anything. what will happen if i tried to use a ecu with a different part number? will it kill anything if i try it?
    TIA
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: ECU compatability
    to the best of my knowledge it won't wreck anything, but it's probably won't work.
    The 557P's in the Passat's and A4's don't recognize any immobilizer stuff and IIRC is ME5. The DBW stuff I think is ME7, and I don't think ME7 and ME5 like each other.
    Jan 07 2007
    for example would a 3B0907551BR ecu work on a car that originally came with a
    3B0907551BQ ecu?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I'm not familiar with that code/pt# It could be a difference between flashes for a Auto trans or a manual, differences in engines - like the older cars that had the option of 8 or 16V. etc
    Jun 01 2008
    Apopka, FL
    the main thing is that it's not going to damage any component, if something major dosen't work you'll know very,very soon ;)
    Jan 07 2007
    no onw knows huh. ill guess ill have to try it and find out. its a 30V btw
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I found that one out today b/c I scanned a 30V at work and recognized the part #.
    What are you trying to interchange? Obviously the ECU, but from year to year, trans, ...?
    Jan 07 2007
    01 to 01 tip to tip, i can recode the softcode for the car if i need to im just want to make sure that a ecu with a different part number will work, i guess it doesnt really matter, i already bought it :) i would check but im ~3000 miles from my car.
