Results 1 to 20 of 20
    In Limbo Three Rings
    Jan 18 2008
    2006 A4 2.0T quattro mt
    central jersey
    AWE vent installed, WHAT A SHOCKERRR
    First off i love the awe gauge, although i didnt get enough red wire to hook up the light, i will be making a trip to radio shack tommrow. I was also amazed how on a revo stage 2 file set from tuner, i am spiking 25lbs and holding 20 ish then drop down to 15 on a stock k03.
    i will put up a better video when my back light is hooked up tommrow.
    http://www.youtube.com/watch?v=8M3wzqYQ7qc
    Jan 01 2008
    Long Island NY
    Re: AWE vent installed, WHAT A SHOCKERRR
    haha you weren't kidding lol. that shit is high. makes me want to switch to Revo and blow my turbo. You interested in meeting up in Old Bridge Raceway and doing some runs?
    Veteran Member Three Rings jimmya4's Avatar
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    can someone explain to me how the pointer is mostly below 0? how can you be pushing negative boost?
    2005.5 Quartz grey A4 Quattro 6mt/ REVO stage II
    Jan 18 2008
    central jersey
    hell yea, i am down to blow my turbo
    Jan 01 2008
    Long Island NY
    negative boost is vacuum. When you turbo is not spooling it reads in Hg not Ibs or bar. A natural aspirated car for example is in vacuum always.
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    will you get alot of boost just by reving? or does it not fully go up unless you are in gear and driving (engine is actually working)
    Jan 01 2008
    Long Island NY
    now that im thinking about it there has to be something wrong with the boost gauge or install. There is no way a stock K03 (tiny turbo) is spiking 25psi and holding 20psi. It just isn't possible. I don't know exactly what could be wrong but a K04 has a hard time holding 23psi.
    Jan 01 2008
    Long Island NY
    Quote Originally Posted by jimmya4 View Post
    In a manual you can barely build 5psi on a 6k launch. Lower launches can barely break 1-2psi. In a Automatic by power braking you can build 19psi of boost b/c the car thinks its moving while in gear. Usually the car doesn't make any boost unless its under load.
    Veteran Member Three Rings kharsnett's Avatar
    Oct 24 2006
    Indianapolis IN
    i can't wait until i save up to get a awe. always have loved there design
    B7 A4 Non sline Sline Edition, High flow fog light holes, Titanium license plate screws, Cross drilled lug bolts, greasy axle, Coolant relief valve on cylinder head, Pressure relieving boost hoses, Cylinder Head Exchange program, Custom cam grind, used fuel pump follower, variable geometry front Control Arms, Automatically shifted manual transmission, 87 octane APR tune, detuned 83 Octane APR tune, Custom high flow Flex section, Custom built spark plugs, Ebay sponsored!
    Jan 18 2008
    central jersey
    Quote Originally Posted by Auditude2.0T View Post
    but my vac is at 20 so how could it be broken
    Veteran Member Three Rings ItsThat2.0T's Avatar
    Oct 28 2007
    Rhode Island
    Yea my vac sits at 20 when idle and I spike at 20
    '07 Quattro A4 Brilliant Black
    | Premium Package | Carbonio CAI | 35% Tint | Trunk Lid Spoiler | REVO | VMR Vent Boost Gauge |
    2 Pedals.
    Veteran Member Four Rings gaede's Avatar
    Jun 06 2008
    fourbanger
    Carlsbad, Ca
    I'm boosting the same numbers with the same tune and gauge, i don't think it's a coincidence...
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    25psi is fantastic if it's under right running conditions! (AFR, EGT, etc.) I say this because something may be wrong, but if there isn't, congrats.
    I'm pushing spiking AND holding 15 on APR, so I think something's wrong on mine (besides PCV).
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    besides the gauge... you were recording video of your boost gauge while you were driving at WOT?? ummm... yeah I'm glad I wasn't on the road next to you haha
    Senior Member Three Rings Jersey Anthony's Avatar
    Jan 17 2008
    2006 A4 2.0T Q M S-LINE
    Jersey
    that was me holding the cam, it was on my cell phone because awe didnt provide enough wire for light
    • Automotive Tailors
    • Velocity Motoring
    • D2 Racing
    Nov 16 2006
    Skokie, IL
    good to hear someone else was recording lol hopefully your boost gauge is working right. Have you tried using a VAG COM to compare the boost levels? This might be a great idea.
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    Wow you guys are hitting 25 lbs of boost?! That's nuts. I have Giac and I spike at 20 and hold at like 18. Maybe I should switch to REVO.
    Aug 08 2008
    2017 Q5
    Houston, TX
    just a shot in the dark here, but if you are able to get comparable games w/ hp/tq on less boost, wouldn't you rather? even though you get less boost on the apr chip, it would be safer on your ride w/ less i would assume. just a thought. anyone have info to clear it up?
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    I love my AWE vent. Best gauge and TRUE color matched illumination ftw
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
    DUH! an Audi
    los angeles, CA
    seriously, I have once spiked to 25, but never hold about 20...I hold rougly 18psi...what am I doing wrong?
