First question for anyone else who has installed a podi boost gauge... are the thin screws that go under the steering wheel, which requires the long neck T8 torx screw driver to remove, supposed to just slip onto the new podi mount, and not screw in like it did on the stock mount? Cause mine did NOT screw in. They just slid in and i'm praying they hold together. Plus the boot covering that keeps the dust out of the steering column didn't snap on properly on my podi mount. the last clips on each side just barely doesn't have enough clearance. Anyone else experience that? And the power and ground wires on the LED light? Why are they only like 5 inches long? It clearly cannot reach ANYTHING that it requires. If you're gonna sell a product... sell a finished product will ya?
Anyways just installed the podi boost gauge last night. it's the analog gauge, not the stepper gauge and I'm wondering what normal readings would be for bone stock.
On cold starts for my car, it will drop to -10 Hg and then wiggle it's way all the way down to -20 Hg, where it will stay at idle.
When I floor the car it peaks at 10 and it stays up at 10 as long as my foot is on the floor. As soon as I let off the floor even just a little bit, it drops precipitously to 5 psi and hold for a little. If I let off the gas ever so slightly more, then it will drop to 3 or maybe 0.
For more normal driving, it peaks at about 5 and then instantly drops to 3 for half a second and then will drop below 0, while I am still giving gas, but not necessarily accelerating and if I am gaining speed it's not a power acceleration. Would that be normal?
I remember hearing that our cars should peak at 12 stock and I understand that not every car will operate exactly at the same pressure. Does it sound like I have any issues?
It doesn't seem normal to me, but wondering if it's just my inexperience in reading boost gauges. Only boost gauge I'm accustomed to reading is the stock one in my sister's Saab and it seems that gauge (although completely different in it's readout format) doesn't seem to fluctuate like this one.
Also, I would like to say that the podi installation instructions for their boost gauge was garbage. Worst instructions I've ever seen. You're selling a product... get that shit together. First of all separate the b7 and b6 installation guides because that shit was confusing at best and could use a little editing from someone who understands linear instructions. Step 1, step 2, step 3, etc. ALSO, indicate what fucken tools you will need exactly from beginning to end. The "$5 worth of electrical equipment" and only the T8 torx screw driver was a little to vague. I kinda ended up using a LOT more tools than that. And what $5 worth of electrical equipment did i need? I don't think i'll ever buy another podi product again until they get their business shit together. No zip ties either? I think 4 feet of vacuum tubing through my driver console, wheel well and engine bay would appreciate a few zip ties, or just put that on the list of required tools. Like i said... confusing at best, but best described as shitty instructions.
