Results 1 to 6 of 6
    May 09 2007
    aeb 2.0bt, 00 bagged 1.8, 93 s-10
    jacksonville, nc
    1.8t engine to 2.8 tranns?
    does it bolt up? can it bolt up?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: 1.8t engine to 2.8 tranns?
    A simple "search" would not only show that it is a direct bolt up but that people have been doing it for years.
    1.8 tranny = 01a housing
    2.8 tranny = 01a housing
    Only difference is the gearing and that the driver side tranny mount which means you just have to swap the driver side mount/bracket from the 1.8t over to the 2.8
    Jun 01 2008
    Apopka, FL
    like mike said, people have done it for years. BT guys like it for the taller gearing.
    Jul 07 2004
    socal
    It is a great mod for the fwy and it a better 1st gear for BT/BAT guys that have a 7k-7500 rpm rev limiter. Down side is that since the gears are talling it takes a bit longer to get thru the gears and it is not a good mod for drag racing if you need to use 4th gear, well unless your car is going to trap 140+ mph with a 8500 rpm rev limiter.
    Oct 29 2005
    10speed
    San Francisco, CA
    if you need me to I can do the swap for you in NJ
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I could not imagine having this trans in my car if I was bone stock. I do like the 1st gear and 5th gear with my current engine set-up.
    -Doug
