Results 1 to 40 of 40
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    For those that change their own oil...
    In my past oil changes i have simply disregarded this part but since i am in the middle of an oil change now i figure i will ask the question. does the metal ring that comes with the filter (not the crush washer) go on top of the filter around the barbs that fit into the filter cap? if so, what i its purpose?
    thanks!
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    May 30 2007
    MA
    Re: For those that change their own oil...
    anyone? anyone? bueller?
    2014 R8 V10 - Gated
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    i have the same question, when i did mine most recently, there wasnt one when i took it out, so i didnt put one back in.
    Dec 05 2006
    So. Cal.
    Everytime i get a filter, it comes with a rubber ring that goes above the threads on the screw on lid. The crush washer for the drain bolt doesn't come with the filter and is purchased separately.
    As far as a metal ring, it must be for a different application that uses the same filter as our cars.
    Veteran Member Four Rings Dodge2Dub's Avatar
    Feb 18 2007
    E90 M3; Ducati S2R 1000
    San Diego, CA
    Do you change your filter at every oil change (5k)? Personally, I change my oil every 5K (Mobil 1) and the filter every 10K.
    Cool stuff with a little growl!
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    Quote Originally Posted by Dodge2Dub View Post
    I just don't think you're getting as much of the old oil out if you don't change the filter. Our oil changes are costly no matter what, so why not throw the filter in there? Not to mention, it doesn't get any easier to change than this.
    Deactivated Three Rings
    Nov 15 2008
    04 Audi S4
    St. Paul, MN
    How often are you supposed to change the oil? 5k?
    Veteran Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2013 S8 | 2006 S4 Widebody | 2014 Q7
    Houston, TX
    According to Audi every 10k after the first 5k change but a lot of people do every 5k.
    Nov 15 2008
    04 Audi S4
    St. Paul, MN
    Dec 05 2006
    So. Cal.
    I change my oil and filter every 3,000 miles. My first oil change was at 1,000 miles and then every 3,000 after that. I change the filter with every oil change and I use Motul Xcess 5/40.
    There is no metal ring that comes with the filters on the RS4. I forgot what the S4 filters come with but I am almost 100% sure that the S4 filters don't have the metal ring either. What filter do you have?
    Hope this helps.
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    i changed the oil on my b5 and b6 and it was a huge mess! never done it on the s4 but i assume it would be much easier and cleaner since the oil filter is in such an easy position to get to.
    just need to make sure you have a large enough oil catch pan because like 9 quarts are going to come out...lol
    Dec 05 2006
    So. Cal.
    Hey Drew, not only are 9 quarts going to come out, but it comes gushing out like the Fricken Niagara Falls. I'm not kidding. Alex's oil change dumped 2 quarts on the floor. No big deal since the floor is sealed and the oil wipes up without damaging the concrete. The second change was Channa's car and I got ready for it and it still swept me away like a fricken Tsumani. Can Audi make the drain plug any larger? It's not like that on the RS4.
    Anyways, I am going to have to buy a new oil catch pan to accommodate Channa and Alex.
    On a side note, I am usually spotless on oil changes, even though C And A probably don't think so.
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    S4 filter comes with 2 metal rings I believe. One is really big and one is very small. No idea what they are for.
    Pela oil extractor is good for taking the oil out then do the regular drain if you think there is some left in there. It won't be messy.
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Veteran Member Four Rings serumk's Avatar
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    If i was going to do one and not the other, I'd change the filter every 5K and the oil every 10K. Seriously, change both every time. No more than 7.5K.
    Mar 24 2008
    khgkhg
    Why would you not change the filter with oil every time? Filter is less than $20 and since you have to spend at least $80 for good oil, what's another $20?
    |^^^^^^^^^^^\||____
    Feb 18 2007
    San Diego, CA
    Honestly, I never really thought about it considering that I new it would be replaced at the dealer every 10K anniversary. I was mostly concerned with keeping fresh oil in the beast.
    BTW, do you guys recommend the two oil filters (non-OEM) that ECS sells, or is it best to stick with the OEM version?
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    IMHO, either of those filters ECS sells are acceptable, and they are actually OEM, IIRC.
    I like to change the oil in my car about every 3k miles like Ed stated above. I prefer the OEM oil filter, its cheap enough where the ECS one isnt too appealing.
    As stated above there are three pieces of hardware that come with the filter. The rubber o-ring which replaces the old one and two metal rings. Only one is used to replace the one on the oil nut. The other is for another application, it is not used.
    Senior Member Two Rings EnjoyIncs's Avatar
    Oct 24 2006
    '04 S4 DG
    Worc MA
    The metal washer that came with my filter was not the same size as the one that was on drain plug. It was a smaller diameter. I was a little worried about replacing it. Should I have?
    Veteran Member Three Rings manhattanprjkt8's Avatar
    Jun 22 2008
    Lots of blown out mounain bikes
    pennsyltucky
    this thread is pretty funny because i just did my oil change this weekend, the hardest part was putting that damn plastic belly pan back on.
    Anyway the little washers you are talking about I don’t believe go with the filter, I had the guy at my dealership pull up the diagram with the part breakdown and they weren’t mentioned at all. I just put in the filter and the rubber crush ring.
    as for the Niagara falls comment, Jesus Christ you aren’t kidding, I went out and bought a 12qt pan for the oil to empty into. Well i pulled the plug and oil comes blowing out (I didn’t realize the hole in the pan was as big as the entire plug most cars it isnt). Needless to say the amount coming out of the pan was more than the catch pan could handles so i had a giant oil spill on the driveway.
    I think i am going to get an extractor for this car, and my future cars i change oil to much to not get one...
    5k should be good, I wouldn’t go 10 it just isn’t worth the risk esp as miles start getting higher.
    Quote Originally Posted by manhattanprjkt8 View Post
    The belly pan is such a PITA. For that reason i cut a nice 4x4" hole in the pan right below the drain plug. No more taking that thing off for me.
    Dec 05 2006
    So. Cal.
    The Bentley Manual states that an extractor is not to be used to change the oil on an RS4. I don't know if it's the same for the S4's.
    Jun 22 2008
    pennsyltucky
    oh really, i wonder why that wasnt brought up in that DIY which was put up a while ago about the '17 min oil chang'
    I think i am going to do the same thing with the belly plate, cut a section in it with a dremel next time...
    Sep 17 2006
    Houston, TX
    Quote Originally Posted by joeycuccaro View Post
    lmao never thought about that. Nice.
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    what do you guys do with the old oil?
    Quote Originally Posted by sakimano View Post
    Take it to a recycling plant.
    Veteran Member Three Rings abe's Avatar
    Feb 22 2009
    2008 S4 Avant, 2015 Q7 TDI, 2017 Q5, 2013 F-450, 2015 Ford Edge SEL
    When I read this I saw chicken Tsumani. Considering we're talking about oil, I assumed it would be a deep-fried dish. Mmmmmm....
    I think changing the oil on a B6/B7 would be a nice easy DIY article. Anyone interested?
    I have 1400 miles on my B7 now. I suppose I should change the oil myself right now. Thoughts? Necessary?
    Onwards,
    -abe
    '08 B7 Ibis White Avant
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    Until I moved to KC, I'd just save it up in a big drum until the next time I visited Toronto. Then I'd stop on the side of the 401 and dump it in some godforsaken part of Ontario.
    Now I'm not sure WHAT I'll do with it!
    Quote Originally Posted by serumk View Post
    lmao
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    Just so I have a useful response in here before he reads that, I think most "Jiffy Lube" type places will take your oil for a minimal fee. Lol. A few dollars?
    Jun 02 2008
    thaaaaat's nice.
    well, I guess since Toronto sends all of its garbage to Michigan for landfill, we have it coming.
    so let me get this straight...
    9 quarts of oil at $9/bottle
    1 filter for $20
    oil dump fee $5
    so $106 for an oil change, and you have to do it yourself?
    WTF does the dealer charge for an S4 oil change? I have Audicare, so I have no idea.
    thaaaaat's nice.
    1 filter for $20
    oil dump fee $5
    10 quarts of Castrol Synthetic 5w-40 - 5.75 x 10 = 57.50 before tax
    1 OEM Filter - $15.12
    Total - 72.62 before tax...
    Not too bad, those were the prices of my last oil change.
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    thaaaaat's nice.
    1 filter for $20
    oil dump fee $5
    LMAO - You can have the fucking Governor back, too. We don't like her. But we'll take your trash - Mmm.... smells like money!
    It seems a time-honored tradition in MI to make fun of the Canadians - one I may never grow out of. But it's just for fun - one of my closest friends is a Canadian, and I actually went to Toronto on my honeymoon.
    To answer your question, "yes." I've always wondered what a dealer charges. I guess I'll check. Molle Audi of Kansas City was rather vague, since they don't get a lot of S4s in for service (I think those take more oil than normal...). He first said $89.99, and when I said that seemed odd since the parts were probably pretty close to that by themselves, he said "Parts plus $22."
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    I paid $55 for 12 quarts of Mobil 1 0w-40 oil plus $13 for the filter (all shipped) the last time. I did it myself.
    Not bad, where did you get it? ECS?
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    I got the oil from an eBay store called CargoLargo (Item# 390036620763), and I work for a dealership, so I got the filter for basically cost, but my dealership obtained the filter from CarQuest (it's a MANN filter).
    So you can't get the deal I did on the filter, but there is still plenty of oil at that place in case you want to stock up! They shipped it really quickly - I was impressed.
    Feb 22 2009
    Quote Originally Posted by abe View Post
    Onwards,
    -abe
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    Lol - sorry. I don't think it's necessary. If I was feeling paranoid, I might change it at 3,000 miles the first time. It wouldn't hurt anything, and if it makes you feel better, go for it.
    Otherwise, 5,000 miles is probably good.
    Senior Member Two Rings psiaddict's Avatar
    Feb 26 2008
    Milwaukee, Wisconsin
    My dealer charges 100 bux for an oil change. Anyone know what oil they use for factory fills?
    Quote Originally Posted by psiaddict View Post
    Pretty sure they use the Castrol 5w-40 for oil changes
