Results 1 to 4 of 4
Thread: Boost leak
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Boost leak
    I made a boost leak tester yeterday with some of intercooler piping and tire valve and an air compressor. Right off the bat I tried to pressurize the system and bam a coupler on the inlet side of the intercooler was pinched off oddly making a small gap and leaking a ton of air. After I fixed that leak The system perfectly pressurized and I went up to about 12psi which is what my car used to boost up to with the leak it was only 7-8. Went for a little drive and man it felt like a new car. I'm making this thread to tell you guys to make a leak tester because it only took like 10 minutes to make and I felt a huge difference. Anyone else have similar stories?
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: Boost leak
    Yeah, boost leaks are a PITA!!!
    As for the thread... do you mean something like this or more like this? Might save you the trouble.
    Mar 04 2008
    West linn, Oregon
    Re: Boost leak
    Yea i followed the first link, but this section gets a ton of traffic, I just wanted to spread the word because I thought it was gonna be hard but it took all of 10 minutes.
    1998 A4 sold
    Dec 05 2007
    Re: Boost leak
    ^Every DIY I came across so far is on point and not as hard as the write up looks. I would suggest anybody whom has problems with thier vehicles (and there is a write up for it) to take the route of the DIY write ups and save themselves tons of mechanic fees.
