Results 1 to 11 of 11
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Blown Headgasket
    I'm trying to diagnose whether or not I've blown my headgasket and aside from the usual symptoms (milky oil, oil in coolant, white smoke from exhuast, etc) what are other things you guys have noticed? Right now these are the symptoms I'm seeing:
    -Occasional overheating
    -Slight loss of coolant
    -Occasional white smoke from tail pipes
    -While cold - pressure is built up in my expansion tank, and when I open it it makes "psssh" sounds and bubbles a little.
    Also on a cold start-up white smoke billows up from around my turbo but I cannot tell if its coming from my head to block or turbo. I'm wondering had I blown my headgasket, would I smoke from anywhere other than my tailpipes? Thanks.
    Some fast things and some slow things
    ~Josh~
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: Blown Headgasket
    Compression test....
    -Sami-
    Aug 26 2005
    Pressure test the cooling system.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Easiest way by far is to use a scope and look into the cylinder from the spark plug hole
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Is your reservoir overflowing while under load? You'd see white residue on the oil filter if it is... I had a combustion leak in my headgasket causing my reservoir to overpressurize. You can get a sample of coolant out of the reservoir and pour it on black asphalt. If there is rainbow hue you are getting combustion gas getting into the coolant system. I just put new bolts in and tightened to spec and it got rid of a leak for me...
    Oct 31 2005
    Virginia
    CoAvant, with your combustion leak did your car ever smoke and have temporary overheating issues?
    ~Josh~
    Feb 12 2004
    Everywhere
    no... have you gotten any fault codes?
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Leakdown test and cooling system pressure test as mentioned by diagnosticator. You should be able to isolate the cylinder that is leaking with those two tests, and a good indie mechanic can do both in an hour or two.
    As Im sure you know, oil in the coolant is one thing, coolant in the oil is another. Dont drive your car around with water in the oil... it trashes the bearings and you'll be doing a bottom up rebuild and not just a top end if you continue to drive it. I suggest you hot plate test your oil for water, or send it to a lab. Blackstone is only $22 for a test.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Oct 31 2005
    Virginia
    I have not gotten any fault codes
    ~Josh~
    Aug 26 2005
    Quote Originally Posted by lookaught View Post
    Leak down test and cooling system pressure test as mentioned by diagnostics. You should be able to isolate the cylinder that is leaking with those two tests, and a good indie mechanic can do both in an hour or two.
    2nd on the advise for a lube oil test by a lab. For commercial and industrial machinery, a lube oil analysis is a routine part of any maintenance or troubleshooting plan. Even if other means determine specific cause of the problem at hand, the analysis info often confirms the source or cause involved. And in every case, the additional info helps evaluate the situation more clearly.
    Feb 12 2004
    Everywhere
    Every oil change from here on out I am getting a test done by blackstone labs. Gave me good insite last round as to how well my engine broke in... $22 is cheap insurance.
