Results 1 to 21 of 21
Thread: upgraded brakes
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    upgraded brakes
    are big brakes really worth it on our cars? Yeah they look a million times better then the factory calipers but are they really necessary? our rotors look pretty damn big! I dont track my car, nor to i drive aggressively very often. I really only want them for aesthetic reasons, which in my mind doesn't justify spending 2k+
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Re: upgraded brakes
    Just an opinion as I know nothing about breaks but have done some research on this. IMHO the rotors are definitely well sized. I don't know how well the clamping force is on the rotor but for me the stock breaks at least size wise seem more then enough
    Jul 06 2005
    Re: upgraded brakes
    Quote Originally Posted by ginkof View Post
    You don't need them at all. If you buy them, it will be based on looks alone.
    If you don't track your car, chances are 99% you will be fine with stock brakes.
    Slow, stock, smurfy blue car.
    Relax, I just troll this place for fun.
    Dec 05 2006
    So. Cal.
    Re: upgraded brakes
    brakes not breaks but I know that you know this.
    op, save your money as the S4's brakes are fine for the street.
    Registered Member Three Rings
    Jul 22 2008
    2006 S4 25th Anniv. Ed.
    Fed Way, WA
    Re: upgraded brakes
    You can always upgrade the rotors to slotted/drilled, and the pads to something that will resist fade a bit better, should you get the urge to auto-x it sometime. But yeah, the stock calipers and rotors are great.
    http://i234.photobucket.com/albums/e...ProfileDay.jpg
    "I think I'm going to get metal legs."
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Re: upgraded brakes
    Rotors are properly sized for street use. Pads however are junk in my opinion so you might want to invest a little there but don't go with ceramic if you decide to keep stock rotors.
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    05 B6 S4, BMW F15 X5
    Southern NH
    Re: upgraded brakes
    Quote Originally Posted by 40valve View Post
    Rotors are properly sized for street use. Pads however are junk in my opinion so you might want to invest a little but there but don't go with ceramic if you decide to keep stock rotors.
    + SS brake lines
    for a small sum of 2K I think you should get them, they look amazing…I know I will when I get some 19" to clear those suckers
    the biggest attention getter on my altima are the brakes, people almost get into accidents staring at them on the freeway instead of paying attention to the road.
    B6 S4 Winter Beast: Supercharger, Carbonio-hybrid Intake, Fast Intentions DP & CB, CF Vented Hood. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/LW rings) & rear BRK, SS lines. Snow tires.
    Daily Driver: BMW F15 X5 M50d clone, DUDMD tune, water/methanol injection, 38mpg highway
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Re: upgraded brakes
    Quote Originally Posted by Stormin View Post
    that is false
    Registered Member Two Rings Lake Powell's Avatar
    Apr 07 2008
    2007' RS 4
    Salt Lake City
    Re: upgraded brakes
    The only thing that needs to be changed is the rear caliper on the RS 4.
    It looks like it came from a toyota.
    Veteran Member Three Rings ZEUSROTTY's Avatar
    Feb 19 2008
    Bolingbrook IL
    Re: upgraded brakes
    I just got braided steel brake lines, had the brake fluid changed out to a higher boil temp fluid, and through some track pads on it... They work well on the track, and the only issue is the squeeling on the street. The pads dont get warm enough on the street.
    2010 S4 DSG Mods None yet...
    Gone 2004 S4 Mods: tinted 25%, APR Dowpipes, w/custom custom cat back including Magnaflow x-pipe Magnaflow bullet mufflers and Flowmaster D40's . Stock intake, APR Reflash - Hotchkins Sways - Koni Yellows front and rear - H&R Springs - Goodrich brake lines - Hawk+'s - Nitto NT05's for the street and 01's for the track. 18" R8 Reps... More to come!
    Jul 22 2008
    Fed Way, WA
    Re: upgraded brakes
    Quote Originally Posted by ngng View Post
    that is false
    You can not upgrade the rotors to slotted or drilled rotors, and replace the pad with something set up to grip better at higher temperatures?
    I would have though that all of the companies selling products to do just this haven't pulled the wool over all of our eyes... But if I am wrong, please do explain.
    Mar 09 2005
    Santa Clara, CA
    Re: upgraded brakes
    kidding :P (guess my smiley didn't go through)
    i would choose slotted/dimpled vs drilled though.
    Jul 22 2008
    Fed Way, WA
    Re: upgraded brakes
    ^LMFAO.
    Seriously.
    I was just getting into this with a ridiculous woman that had that "I'll disagree with you just to pick a fight" moment they somehow have (for some reason, all of the women that are reading this are the exceptions to the last statement and never have that issue !).
    You can't type sarcasm without the smiley. It's the smiley's gift to the internet. Put one at the end of the post (perhaps with a "j/k") and it's fine to be a total ass!
    Nov 28 2007
    Massachusetts
    Re: upgraded brakes
    any recommendations on street pads that will grip well and not fade to quickly? Are there aftermarket pads that work with our factory warning light? Any recommendations on rotors? where to get them from... etc.
    Is it really worth getting RS4 rears? or is that for aesthetic reasons?
    Senior Member Two Rings khyber's Avatar
    Nov 21 2007
    B6 S4
    Socal
    Re: upgraded brakes
    Isn't one benefit of upgrading brakes the fact that most kits are lighter weight than stock? Every little bit of unsprung weight you can reduce works wonders.
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Re: upgraded brakes
    Quote Originally Posted by khyber View Post
    This is true.
    I have them, and the benefits are looks and weight, but there are NOT needed.
    Veteran Member Four Rings Dodge2Dub's Avatar
    Feb 18 2007
    E90 M3; Ducati S2R 1000
    San Diego, CA
    Re: upgraded brakes
    What about the ECS Tru Float kit? Any good?
    http://www.ecstuning.com/stage/edpd/...productID=4121
    Cool stuff with a little growl!
    Sep 23 2006
    Houston TX
    Re: upgraded brakes
    The pedal feel will be a bit different, but overall as everyone here has said performance gains on the street will be insignificant. Some Motul 5.1 and better pads will go a long way for the price. But they do look badass.
    Jul 21 2004
    South Florida
    Re: upgraded brakes
    Quote Originally Posted by Dodge2Dub View Post
    I didnt find the rotors that ECS has built (rom Coleman Racing) to hold up to track use. They have superwide air gaps and fewer directional vanes for cooling and couldnt take the heat near as well as the stock rotors.
    cheers! Mike
    2018 Audi S5
    Gone-
    Feb 26 2008
    b7s4
    Re: upgraded brakes
    keep them stock for the street
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    Re: upgraded brakes
    You can get the SS lines, fluid, and new pads like everyone else said. That should upgrade your brakes enough to the point where you'll be satisfied. However, if you have interest in any BBK let me know. We can do anything from Brembo to Alcons to AP Racing. And we're offering free shipping as well.
