Results 1 to 6 of 6
    Senior Member Two Rings kengvang's Avatar
    Jul 11 2007
    2000 AUDI S4 TIP
    milwaukee, wi
    need help!!! engine speed sensor!!!
    hey guys, my car is dead and wont start. 2000 s4 tip. i need help on finding the engine speed sensor location and a part number or location on getting a replacement part. how hard is it to change out?
    thanks,
    keng
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: need help!!! engine speed sensor!!!
    i googled it, and through multiple sources got "sensor G 28" as a number commonly referred to as the Engine speed sensor.
    I'm not sure where it's located on the 2.7t, but maybe someone with access to a Bentley manual could help out.
    this site has the location for i believe the 2.2t: http://forums.audiworld.com/s4s6/msgs/116988.phtml
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Senior Member Two Rings Tokin's Avatar
    Nov 28 2007
    Audi S4 and Tiburon
    Daytona Beach
    It's on the drivers side of the transmission, accessible from underneath. It is just above and forward of the half-shaft, connected directly to the trans. You'll need a 10mm wrench.
    Jul 11 2007
    2000 AUDI S4 TIP
    milwaukee, wi
    thanks for all the help man.
    Senior Member Two Rings Shi-Fu JaY's Avatar
    Apr 06 2008
    Fontana, SoCal
    engine speed sensor is also known as crank sensor right?
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Shi-Fu JaY View Post
    Yup. It's a reference sensor to verify timing.
    08 S4- Stock SOLD
