Results 1 to 6 of 6
    Senior Member Two Rings mtxsho93's Avatar
    Sep 20 2008
    93 SHO, 02 A6 2.7T 6MT
    South Jersey
    camber adjustment
    Does anyone offer adjustable control arms or strut mounts for our C5 A6's? My car has the sport suspension but I'm not sure if the previous owner lowered it even more. With the BBS 18's that are on it, it appears that the tops of the wheels are slightly tucked in. I searched for adjustable control rods but couldn't find anything for our platform.
    Thanks,
    Ian
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: camber adjustment
    CPP makes adjustable control arms, but I don't think they are widely available anymore (rumor was CPP closed it's doors)
    KMAC might be better suited and easier to find. just search it out
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Yea CPP is closed now, but like as he said, KMAC.
    I have the CPP on my B5 A4 and i love them. My camber is perfect and the alignment guy said it was a breeze (and noted it was pretty cool) adjusting them,
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 20 2008
    South Jersey
    Awesome thanks. I saw a reference for the CPP's somewhere but when I searched I couldn't find anything. I'll look for the KMAC's.
    Ian
    Sep 20 2008
    South Jersey
    So, I looked into the KMAC's - they are eccentric bushings, right? Correct me if I'm wrong but when people replace their OEM control arms, they are doing it because the bushings are worn, correct? Therefore, it would be logical to keep the arms, press the old worn bushings out and replace them with the KMAC's and have 100% functional arms with new eccentric bushings?
    Thanks,
    Ian
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by mtxsho93 View Post
    Thanks,
    Ian
    Exactly correct. The only reason you'd replace the whole arm is if the ball joints on the arms were worn out.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
