Results 1 to 6 of 6
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    those with startup gt coils... got a question.
    i was just checking out my coils and noticed something. it says that the springs should have the following markings:
    front springs are marked with a 'VA'
    rear springs are marked with an 'HA'
    now i know which one goes where just by looking at the size of it, but none of em have the markings mentioned above. just wanted to make sure its all good before i start the install. here are the markings on my springs
    that rear spring is tiny huh.
    am i good to go?
    Dec 27 2005
    Ft lauderdale
    Re: those with startup gt coils... got a question.
    oh and what ride height are they pre-set at?
    Veteran Member Four Rings johnnybravo!'s Avatar
    Feb 20 2006
    323 EASTLOS, CALIFAS
    Dude your good to go..Tomasz is the man and my Startup/ VogGt has been well worth the $$..i have stiffer/higher rated rear springs than u..my height was set at 25 1/4" front..25 1/2 rear..any lower looks way dumped..hope that helps..
    SRM K24 - Bosch 1000cc - Rods - 2.8 Cams- RR STG 4 clutch - AA-built 01E+4:1 - OS Giken LSD - ER IC's - JHM SS - SRM DPs - Vibrant 3" - Vast W/M - RS4 Y-Pipe - ASP MAF - APR Bi-Pipe - Ohlins MS Coilovers - AP Racing BBK - 034 Rear Sway
    C7 A7 Silver- Jackal STG 2+E40 Shane Horning ported s/c Merc HX- Pierburg 100-3 - Eibach Springs- OZ 20" UL wheels/Michelin PS4s- Eurocode Sway Bar- Borla- IE Intake
    Audi. Truth in Understeering.
    Dec 27 2005
    Ft lauderdale
    how d'u have stiffer higher rated rear springs me? i thought the startup gt's are the one's with higher rated rear springs, i.e. the ones pictured above?
    also, the height you have.. is that the height startup gt's come pre-set at?
    Nov 09 2006
    08 cooper S, 97 C4S, 95 C4
    Tacoma, WA
    You are fine, & have the proper kit.
    The heights are set for packaging, not for the road. Best starting height, is to match the spring perch to the stock shocks, then add a couple of turns up, this will be about 1-2in lower then stock.
    Dec 27 2005
    Ft lauderdale
    good to hear... thanks mike
