Results 1 to 11 of 11
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    B7 S4 Suspension on B6 A4
    Will the OEM suspension from a B7 S4 fit a B6 A4 3.0 Quattro?
    Veteran Member Four Rings italian a4 1032's Avatar
    Oct 17 2007
    mass
    Re: B7 S4 Suspension on B6 A4
    im not positive but isnt b6 and b7 suspension the same
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    yes, will fit!
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Sep 14 2007
    2004 A4 1.8T, 93 Ford Festiva
    Nazareth, PA
    If it is the same, how will the ride be on an A4 if its a 1.8 given that the B7 S4 is heavier. I rolled around that idea instead of installing the coilovers i have cause i really dont need all the customization, just a small drop
    May 03 2007
    german
    heaven/hell
    ride will be firmer
    Oct 17 2007
    mass
    Quote Originally Posted by snafooz1 View Post
    just get an 02 sport suspension from the classified for cheap
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Well consider the S4 has a V8 up front and is a lot heavier, the front of your car will be sitting a little higher and your ride will be a lot stiffer, just pass on it. Good spring can be had for under $200 new.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Jul 04 2008
    York, PA
    I have a 3.0 so I think they will work fine. Does anyone know what kind of drop I'll get with them?
    Jul 04 2008
    York, PA
    Will these lower my car at all?
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by 4Rings3Liters View Post
    No more than an OEM sport suspension, which I figure the S4 suspension would be akin too. The difference in handling comes mostly from the rear S4 swaybar. Like I said you'd probably get better performance from a set of after market springs. Your car won't be lower with an S4 suspension, which is good if you planned on reusing your stock shocks, that's really the only advantage.
    Oct 22 2005
    Reppin the Mitten.
    Search...This has been discussed over and over again. The spring rates for the S4 is drastically different then the 3.0 or 1.8t. No point in putting springs that weren't designed for your car. Chances are you will only get a firmer ride, and probably a higher ride then your oem sport. Do it right, or do it twice.
