View Poll Results: which HFC?
Voters
13. You may not vote on this poll
  • 034 motorsport
    9 69.23%
  • Techtonics Tuning
    1 7.69%
  • other, pls post in thread.
    3 23.08%
Results 1 to 13 of 13
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    High Flow Cat - 034 or Techtonics Tuning?
    any one have any experiece with these HFC's? any other good options beside miltek?
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Re: Poll - High Flow Cat - 034 or Techtonics Tuning?
    I've heard that for the price the Miltek is not worth it. Can you not have a test pipe where you live?
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    i have a tttuning HFc, have had no issues with it.
    034 makes good products so really if i had to do it again it would be a flip of the coin.
    the miltek is way over priced if you ask most people. the miltek is 200cell, while the tttuning and 034 are 250cell i believe.
    Passed the New Hampshire emissions inspection.
    Aug 16 2004
    SE PA
    Quote Originally Posted by Killerteve View Post
    no test pipe.
    May 21 2007
    Florida
    i talked to labree motorsports about highflow cats when i was doing my exhaust. i was told by them that the average lifespan on them is about 1 1/2-2 years before having to replace it. i would do some research and talk to the companys who sell them to see what they say about it and how long it would last. that would be one of the main things i would care about buying a HFC.
    2018 Navarro Blue Q5
    Apr 12 2007
    Milwaukee
    uh what, catalytic converters should last almost the life of the car if the engine is running perfectly.
    Dec 25 2004
    Earth
    The Fast Intentions HFC's work, but you will still get a CEL, as they dont work well enough....
    The Milltek is a more sophisticated design-
    Your original catalytic converter will typically have 400 or 600 cells per square inch (cpsi), these original cats are restrictive in their flow, typically allowing an open area of around 55-65%.
    A Milltek Sport Hi-flow Sports Cat which will be fully integrated into a large bore downpipe, has only 100-200 cpsi depending on application. These cats have an open area of between 75-85%, thus reducing back pressure substantially and increasing flow rates, all very desirable for extracting more performance, especially on turbocharged engines. Emission levels are maintained at legal limits by careful selection of the volume of the metallic substrate.
    The honeycomb is held together by using a special nickel-based brazing material which is applied in a vacuum. The finished honeycomb is then coated with Aluminum Oxide, some rare earth metals and Platinum and Rhodium. The Platinum and Rhodium are applied at a rate of 25 grams per cubic foot, which compares with between 5 and 10 grams per cubic foot for typical US aftermarket items.
    It is normal practice in Europe to use much higher quantities of precious metals on catalysts, because European gasoline has more impurities in it which gradually poison catalysts. If catalysts with such high levels of precious metals are used with US fuels, the post-catalyst emissions are extremely low and the durability of the catalysts is very good indeed.
    This is why it costs more....more rare metals of Platinum and Rhodium, and a better design/quality.
    They make it larger, to accomidate more flow, then increase the rare metals so it cleans better, and at 200 cells per inch, it does so better than any US made HFC!
    This is one time US tuners should take a close look at the Milltek, and follow their lead!
    Maybe then we could get a lower priced HFC, which performs as well, but is built here in the US, and not have to pay the difference because of the dollars poor showing against the EURO!
    Veteran Member Three Rings dewey527's Avatar
    Mar 10 2008
    '02 a4 1.8tq, '05 tahoe
    Puyallup
    i love my tantrumwerks 300 cell hfc and i did not get a CEL they also have a 200 cell but i didn't want the extra noise... still a family car.
    mods - not enough for me and way too many in my wife's opinion
    K04, Revo "Stg2", PODI Boost Gauge, TT225, fmic, Forge DV, Tantrumwerks 300cell HFC, Neuspeed Exhaust, Stasis Touring Suspension, Spec Stg2 & LWFW, 034 RSB, Neuspeed SS, Neuspeed Snub, Neuspeed TIP, B6S4 front brakes, Tyrolsport Kit, 6K HID, Yellow Fogs, 20%, CC
    Jun 30 2007
    Raleigh, NC
    Re: High Flow Cat - 034 or Techtonics Tuning?
    034 ftw.
    i'd still recommend that you get a TP over a HFC though
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Ok now if the HFC wont get rid of the CEL and therefore won't pass emissions, is there any accurate estimate as to how well it actually "cleans" the exhaust? Is one brand better than the other (regardless of cost)?
    For some of us tree huggers, a test pipe is just not an option. Pollution is bad enough as it is, I try my best to limit my contributions.
    Flame away.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Four Rings MultiAudis's Avatar
    Mar 12 2006
    01 Allroad 6mt, 01 A4
    NoVa
    I run a ghl hfc and it passes VA emmissions no problem (stricter than PA)
    Apr 20 2007
    Lander, Wyoming
    Quote Originally Posted by MultiAudis View Post
    ghl? link? price?
    Jon
    go > show
    Ich liebe mein Audi
    Aug 16 2004
    SE PA
    no CEL?
