Results 1 to 16 of 16
    Established Member Two Rings jstrat812's Avatar
    Mar 09 2007
    Scottsdale
    Exhaust... Bolt or Weld?
    I was calling around today to get an install quote on my Magnaflow cat-back. I told one of the mechanics that this exhaust directly bolts on. He said that it will come loose and eventually rattle. I would like to bolt instead of weld it on because of resale value.
    Any thoughts as to which is better? Bolt or weld?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: Exhaust... Bolt or Weld?
    Huh?
    Diy
    -Sami-
    Veteran Member Three Rings passatkid's Avatar
    Sep 19 2006
    ND
    Bolting won't come loose if you use no nylon locking nuts, with lock washers.
    Dec 19 2007
    York, PA
    he doesnt know what hes talking about. Bolt it on for christs sake...mostly ALL factory exhaust systems bolt on...what the hell is he talking about?
    Dec 31 2006
    boston, ma
    which kit is it?
    Mar 09 2007
    Scottsdale
    Thats what I thought.
    I have the Magnaflow 16600 system. The tips look amazing!
    Dec 31 2006
    boston, ma
    i just installed mine today....you definitely dont want to weld it.
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    bolt it on... the bolts expand when heated (ie running your car) and i'm sure it wont rattle... between me, my brother, and my friends, we've put around 30 exhausts on and none of us has a welding machine. everything is good.
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    WTF! that guy is retard, its actually the other way around lol, if you straight weld it on the exhaust cant move on the donut and will crack and break the welds, now you can install a flex pipe in the exhaust so that dont happen, but then your just straight ghetto riggin your exhaust lol, there is a reason why every oem exhaust bolts on, i suggest just do it yourself and save some money its really not very difficult.
    Dec 31 2006
    boston, ma
    that system really isnt a bolt on anyway...its more of a slide on
    Dec 19 2007
    York, PA
    ^"slip joint"
    Dec 31 2006
    boston, ma
    ^^ thanks but i was making a joke
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    If you want the best way go Vband.
    May 21 2007
    Florida
    yup ide say that system should be doable in a driveway on ramps or jacks. not much to it.
    2018 Navarro Blue Q5
    Aug 26 2005
    Quote Originally Posted by passatkid View Post
    Yep, the type of locknut is called a "Prevailing Torque" lock nut. They are crimped to grip the bolt threads.
    Dec 06 2007
    wait a minute mine is welded from flex pipe back, i thought welding was the best solution.
    -Kirk
    BetaAlphaTau Member #58
