Results 1 to 20 of 20
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Oil on diverter - normal?
    I had to give up putting in my Forge 007 for the night. Those one time use clamps got the best of me - will regroup and try again tomorrow.
    I notice that the two larger DV hoses were wet with oil (on the outside). It looked like it was pretty old oil because it was black. It also wasn't very thick - almost like black water. I just changed my oil a week or two ago, and the level is exactly where it was when I changed it.
    Is it normal for that area to get oily?
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Feb 19 2008
    V8 powa!
    Texas
    Re: Oil on diverter - normal?
    Pretty normal to see oil residue in the intake tract on any turbo car. Especially when boost is above stock.
    May 03 2008
    Orlando
    thanks for the reply. I guess I'm concerned because when looking at Martini's pics on A4mods.com, his DV area is dry and pretty.
    Kevin W.
    Aug 03 2007
    2003 A4 1.8T QTip Sport Avant
    Denver
    I'm thinking about changing to the Forge 007 myself, and am looking for some info on a DIY.
    What are you using for guideline? Any suggestions would be great once you get it installed.
    Good luck
    May 03 2008
    Orlando
    Forge has a decent writeup on their website - a4mods.com has one too. It's pretty easy to see how to do it once you get under there. The hard part is just getting the clamps off the old one. The spacing sucks - I have a cordless dremel and couldn't position it to slice off the crimped part of the clamps. I'm going to use snips tomorrow.
    Kevin W.
    Aug 03 2007
    Denver
    Gotcha, thanks for the heads-up.
    I thought I read somewhere that the old clamps should 'pop' right off with a screwdriver, but I guess not!
    What kind of clamps will you use for the install?
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    installing the dv is not hard. those clips are best taken off with a grinder. trust me it took me forever and i resorted to a small grinder and just grind them off carefully. after that use pipe clamps and you'll be set. its not hard to do just pull off the belly pan and the DV is just behind the fan on the front right of the car by that radiator.
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    May 03 2008
    Orlando
    Quote Originally Posted by ganuza View Post
    oldguy sent me a PM with a link to this thread - a screwdriver should do it - going to try this method tomorrow. oldguy rocks - always there with a humble PM to point us in the right direction.
    http://www.audizine.com/forum/showthread.php?t=214195
    I have two worm clamps that will fit the large hoses, but I'm probably just going to use zip ties since I'll have to take the thing back out to service it later on. Although - worm clamps might be easier to take back off than snipping the zip ties. Guess I'll decide when I'm under the car tomorrow!
    Kevin W.
    Aug 03 2007
    Denver
    Great info - thanks again
    'Old Guy' is awesome! He gave me some pointers for doing my fuel filter replacement.
    May 03 2008
    Orlando
    Finally got the damn thing installed. The screwdriver method wouldn't work on the clamps - I just couldn't position the screwdriver the right way given the way the clamps were turned. Used snips and dremel.
    Also - I figure out the name of the other thing that has oil on it - the boost reservoir. What would oil around that area point to? It's like black water - on the bolts to the boost reservoir and generally around that area.
    I don't have any symptoms other than the residue all over - my boost and vac levels are normal, idle is super smooth, driving is normal, plugs looked fine when I changed them, no drips on the driveway, oil level staying constant, coolant looks good, no smoking or burning smells...
    Kevin W.
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Are you talking about that metal thing that is bolted to your engine block, that connects to the DV pipping?
    May 03 2008
    Orlando
    Quote Originally Posted by J-jizzle View Post
    yeah - it's silver - kinda shaped like a cowbell or something.
    Kevin W.
    Aug 28 2007
    O. I took mine off but I don't remember any residue on it when I did.
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    sorry to threadjack, but does anyone have a yellow spring they would sell me
    Some fast things and some slow things
    ~Josh~
    May 03 2008
    Orlando
    Quote Originally Posted by mtbrider View Post
    Well, your threadjack gave me a bump at least.
    To answer your question, no! I had to go to my local tuner to buy one for 3 bucks. Do you have a Forge distributor or tuner nearby? They should have them laying around.
    Any more thoughts on oil residue around the boost reservoir area?
    Kevin W.
    Registered Member Two Rings zims666's Avatar
    Apr 17 2008
    '05 A4 B6 1.8t 6speed
    Chapel Hill, NC
    Quote Originally Posted by kwimberly View Post
    "my other ride is your daughter"
    May 03 2008
    Orlando
    yeah, but silver. I've got a fever, and the only prescription is more cowbell.
    Kevin W.
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    gotta say oil around boost reservoir is odd to me too. When I removed mine it was bone dry.. and really clean actually
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    May 03 2008
    Orlando
    crap. I wonder if it's a leaky hose or something. The bad thing about our belly pans is that they can probably hold half a quart of oil, so who knows if I have a slow leak or not!
    I might crawl underneath again this weekend and take some pictures. That'll also give me an idea of how bad it is because I wiped it all down when I was doing the DV.
    Kevin W.
    Veteran Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    Like mentioned above. It's normal to see oil residue around the dv, keep in mind everybody drives in different enviorments. Its also common to see oil residue in the intercooler pipes.
