Originally Posted by
djwimbo
It also depends on the thickness of the flywheel's friction surface.
If you machine a flywheel the overall "depth" of the pressure plate moves down, thus moving the engagement down on the pedal.
Actually that should make it higher on the pedal. The same as the disk material wears or the pressure plate surface is cut/wears.
airy52
Thanks for the help mike that helped me understand.
Why aren't you ever on AIM anymore?
I emailed SB to ask a few questions etc etc. If I go LWFW I have to return my clutch for one that will be usable with a LWFW because I bought the DMFW one thinking I could get it resurfaced locally. Is it really worth it to get it resurfaced? Or can I do a good enough job with a scotch brite pad? The rivets on the pressure plate have put a divet in the flywheel and isn't very small.
edit: like ka4 below me said, i agree and was wondering the method people used on this, but screw it I want to do a good job.
Haven't been on much lately since I haven't been online as much as usually.
Well you can use the unsprung hub disk on a lwfw but you will notice more chatter. I am sure if you want to go with a sprung hub disk it shouldn't be a big issue getting it exchanged.
The stock flywheel can only be resurfaced a few times depending on how much needs to be taken off.
