I've been running my VVT solenoid unplugged since I installed my Cat 3658s causing a CEL. Today I decided to fix a few things and this was one of them. I removed the electrical portion of the tensioner to see what how I could leave it plugged in but have no CEL. CoAvant (Jordan) took a spare one apart to see how it worked. He suggested pulling the pin that moves the oil control piston, I tried that and it wouldn't budge. So I thought about cutting it off, no dice, no way to hold it. So I took the piston out of the tens. and center punched the end of it where the pin hits the piston. I then drilled a hole in it larger then the pin so when th ECU actuates the solenoid the pin just goes thru the piston.n CEL solved. I now roll CEL free!!!!!!!!!!!!!
