Results 1 to 2 of 2
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    what size bolts secure the transmission to the engine
    what size are the bolts that secure the transmission to the block? I need to pick some up from Ace hardware. The reason I am asking is I am going to be securing the motor to an engine stand I have.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Aug 13 2008
    Indiana
    Re: what size bolts secure the transmission to the engine
    dont you have one of the ones that holds it on? If so and there not long enough to use with the engine stand just take it with you and find a nut that fits it then find the right bolt that way.
