Results 1 to 3 of 3
    Senior Member Two Rings audiholix's Avatar
    Jul 18 2007
    335xi coupe / 8p a3 / b5 a4
    18x8 ET38 225/40/18 on b5?
    Hi,
    Will 18x8 et38 225/40/18 fit right on a b5 quattro? thanks.
    08 a3 2.0t
    10 a4 quattro
    Apr 25 2007
    millersville, maryland
    Re: 18x8 ET38 225/40/18 on b5?
    yeah they should work with no issues the smaller 225 tire should prevent most rubbing from occuring.
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Offset looks a little high to me, might need a spacer (we normally use ET32 to ET35). We use 235/40-18 as the only tire size for your application (would need your GAWR to see if the smaller tire is safe or not)
