Results 1 to 3 of 3
    Feb 09 2008
    did a search - but what size is the slave cylinder bleed valve
    It seems 10 mm is too big but 9mm won't fit....
    Is there such a thing as half-size on this stuff.
    Trying to bleed and cannot find a good fit for the bleed valve.
    Thanks all...
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: did a search - but what size is the slave cylinder bleed valve
    probably 8mm then...its definitely not a half-mm size
    -Sami-
    Feb 09 2008
    Thanks for the reply - took a trip to Sears. It's 9mm while the brakes are 11mm for the bleed valves. Kind of wish they kept it all the same but there you go.
