well, i tested my car for boost leaks today, and turns out i have none, but now my car is smoking.
it was really bad at first, and i figured pressurizing the intake forced oil into the exhaust or something and it would burn off (it certainly smokes less now), but after driving about 60 miles, its still smoking. I don't really see how a checking for boost leaks will cause this, and i figured the oil would be burnt off by now.
so my question is:
is it possible i damaged the seals in the turbos?
no dentist drill noise, not making a ton of smoke like failed turbos do, just a little bit at idle. I'm going to look into the crankcase ventilation system tomorrow, but i'm hoping someone has had a similar issue and can chime in and help.
