Results 1 to 6 of 6
    Established Member Two Rings DubAudi3's Avatar
    Aug 14 2007
    01 a4 1.8tqms
    Canton, CT
    wastegate loose? normal?
    Just looking for a quick response..
    In the process of putting a testpipe on my car i wanted to check out the turbo .. The turbine itself felt fine, the wastegate in the turbo felt kind of loose, it moved around a little bit. No idea if this is normal. I have some cellphone pics but probably wont show anything...
    Hopefully this is normal and im just paranoid
    thanks
    01 A4 1.8T QMS
    www.BishopMotorsports.com
    Canton, CT (PM me for details)
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: wastegate loose? normal?
    Are you having any boost related issues or did you just notice it upon inspecting it?
    Aug 14 2007
    01 a4 1.8tqms
    Canton, CT
    Just noticed it. i thought it was spiking kinda high in 3rd and 4th gear sometimes 23-24 lbs.
    01 A4 1.8T QMS
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    so, then you are fine.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    its only a problem if your not getting enough boost ;)
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Aug 14 2007
    01 a4 1.8tqms
    Canton, CT
    thanks guys
    01 A4 1.8T QMS
