Results 1 to 12 of 12
    Senior Member Three Rings Caddy7's Avatar
    May 26 2008
    Silv -00 S4 Tip & -01 A4 2.8L
    Riverside, CA
    Grinding front Calipers for clearance
    I just bought a set of B7S4 18" (S-line) wheels, now the front caliper is tuching the spokes.
    The wheels have offset 35, I want to minimize the use of spacers.
    So the question is:
    Would shaving of a few mm off the calipers be a good idea or a really bad one??
    Aug 06 2008
    Canadia
    Re: Grinding front Calipers for clearance
    I won't say if you should do it, but i would do it.
    May 26 2008
    Riverside, CA
    Thanks for the input... I think it look strong enough to cut som off it, but has anyone tried?
    Jun 12 2008
    Four Rings
    TX
    I took off about 2mm on my A6 to clear my front wheels (+35mm offset), but I don't have HP2 calipers.
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    its fine to take a little off
    the homebrew'd s4
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    took 3-4mm off mine, no big deal
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    agreed. did it on my se-r sentra. go for it if you really want to fit them. or just get some spacers (i know you say you dont want to)
    May 26 2008
    Riverside, CA
    Thanks guys,
    Any objections before I start grinding away??
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Quote Originally Posted by Caddy7 View Post
    Thanks guys,
    Would you care to buy my ACME anvil and dynamite?
    l gotta-- l gotta get
    a form from a scientist.
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    I have those same wheels and they are actually ET43. I put on 8mm spacers upfront as opposed to grinding my caliper. I also recall having to use a spacer in the back (I'm pretty dumped, though) to clear the bar, 20mm spacer back there.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    May 26 2008
    Riverside, CA
    I just finished the install.
    Grinded 3-4mm and still had to use 5mm spacers (and new bolts). My brakepads are new so that might have contributed to an even tighter fit. In the rear I did not need spacers but I used same 5mm there also just for consistency.
    First I tried stacking 2x5mm (10mm) in the front, this cleared the brakes but stack out to much. I am pretty sure my wheels are ET35.
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    it shouled say on them some were what they are, for example my ottie's have it stamped on them and my stocker as well, just look them over real good and you will fiend them, My et 35 rims clear with no issues at all with new brake pads, think yours is less than 35 good luck
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
