Results 1 to 9 of 9
    Veteran Member Four Rings 02SILVANT's Avatar
    Aug 24 2007
    2005 Audi S4 Avant 6MT
    Vancouver, WA
    Question about B6 S4 headlights
    I found some B6 S4 headlights in the classifieds and was wondering will they just be plug and play if wanted to put them into my A4, i currently have stock xenons and self leveling thingy. The S4 housings came of a 2004 and i have a 2002.
    TIA
    -Vito
    2002 Silver A4 Avant Auto - SOLD
    2005 Black S4 Avant 6MT - SOLD
    2005 Mercedes E500 Sport - SOLD
    2005 BMW 330ci ZHP Convert imola red with hard top - SOLD
    Currently 2015 Audi Q7 3.0T S-Line V12 TDI Body Kit
    SPARK, Mental Focused Energy Drink:https://www.advocare.com/08082595/St...lavor=L&size=P
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Re: Question about B6 S4 headlights
    Quote Originally Posted by 02SILVANT View Post
    TIA
    -Vito
    Are the S4's bi-xenons?
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Aug 24 2007
    Vancouver, WA
    I asked the guy the same thing and he said they are single but as much as i know i think just about all S4's came with bi-xenon.
    Sep 02 2005
    Montreal
    Not all S4s had bi-xenons: http://upload.wikimedia.org/wikipedi...04_Audi_S4.jpg
    Yes, it's plug-n-play.
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    It depends.
    Some 2002's used a different bulb. There is a DS1 and a DS2 and I can't remember which is the odd one. Anyway, if you have the correct bulb (the only way to know is to pull yours out and look) then it will be MOSTLY plug and play.
    1. You may have to modify the back cover of the S4 housing to accommodate the access of the ballast plug. It's simple if you have a dremel, and not a big deal if you have a drill and a hacksaw. Once the ballast is installed, silicon and exposed areas just to be sure you don't fog up. P.S. you're new lights will fog up. S4 light are prone to this do the o-ring fix, then plan to do it again.
    2. You will have to move one wire in one of the sockets of each S4 housing to match the arrangement on your stock xenon. takes 5 minutes. The sockets are the same, and you should take the extra time to mark where the wire came from and where you are putting it, just so that you can switch is back if you need to.
    3. High beam bulbs are not the same in S4 as in stock xenon. I believe they use H11 bulb type, but can't remember for sure. Do a search and something will come up.
    I started a writeup last year when I did mine, but never finished it. I unfortunately do not have time to finish it now, but hope that this gets you started. I have an 02 as well.
    good luck.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    May 22 2007
    oakland ca
    If the S4 housings from the classifieds are the ones with bulbs and ballasts, then yes, they are a direct plug and play.
    The only other thing of note, is that the back of the housings are very slightly deeper on the s4's are it is a pretty tight fit getting the cables to run to the right places.
    550 is a pretty good deal for basically new housings that come with everything.
    Aug 24 2007
    Vancouver, WA
    ^^^Ya they are the ones for $550 from the classifieds with the bulbs and ballast.
    Thx for the info guys!
    Sep 02 2005
    Montreal
    Quote Originally Posted by cjonesgo View Post
    Early MY2002 (manufactured before November 2001) used D2S bulbs with the 4G ballast. If he has this system, the housing will most likely require a modification but the cover holes will line up fine.
    Aug 24 2007
    Vancouver, WA
    Im running the D1S bulbs and ballast.
