Results 1 to 21 of 21
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    All of the sudden, horrible vibration starts + CEL flashing... Any ideas?
    1999 Audi A4; 1.8T Quattro; Manual
    Okay, I was driving home from work today, when I go to change lanes and start accelerating, I feel a horrible vibration... At about the same time, my CEL starts blinking and I am forced into LIMP mode. Thinking it may have something to do with my ECU (since I have had problems with it in the past) I pull over and stick the stock 557P back in... Still got the vibe, blinky CEL and LIMP mode... Anyone have any ideas what could be causing this?
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Dec 05 2007
    Re: All of the sudden, horrible vibration starts + CEL flashing... Any ideas?
    First thing first. Get your car scanned for codes.
    May 04 2008
    Columbia, SC
    ...waiting to get in touch with a buddy with VAG-Com...
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Did you drive through a puddle of water? Check your fluid levels too
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Could be the ecm too... I've had both go bad, ECU and the ecm... Same symptoms you describe for both situations. A scan should confirm if the ecm is bad. May not confirm if your chip is loose/not connected properly. Could be the the chip is loose if the install sodder work was bad.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    Quote Originally Posted by nrowensby View Post
    i'd put alot of money on a bad coil pack. you will probably get a "misfire in cylinder" 1,2,3 or 4 code. about 50 bucks at the dealer. all of 2 minutes to change it, easiest job on the car..............
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Sep 01 2005
    if you don't own a vag com, they sell the pocket scanners at advanced, or other auto places for under 60 bucks. does the job..........if not they will scan it for you for free.
    May 04 2008
    Columbia, SC
    Okay... I got the car home and started some self-diagnosis since I couldn't get ahold of VagCom and didn't want to drive her in her current condition to a parts store... Started pulling plugs on coil packs... pulled plug 1, car almost shut off... pulled plug 2, no change... 3 & 4 almost shut off... I guess I need a new coilpack for cyl2
    Sep 01 2005
    so i guess i was right, i've changed all 4 of my coils already, just a heads up, when one goes the others follow suit, and sometimes leave u stranded.
    plus i would VAG it and make sure what your code is before you go buying any parts.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    Quote Originally Posted by boostedup View Post
    QFT
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Sep 01 2005
    Quote Originally Posted by maxspeed View Post
    QFT
    qft?
    May 04 2008
    Columbia, SC
    http://en.wikipedia.org/wiki/QFT
    ::scratches head:: ???
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    qft isnt that like a pussy fart...
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
    Sep 01 2005
    Quote Originally Posted by UN-PIMP-Z-A4 View Post
    lol queef??
    Quit Fuckin Talking
    Quite Frankly Truthful
    Quit frying turkies
    Quit Fondling Tits?
    never seen that abbreviation, sorry a little lost
    Veteran Member Three Rings AudiTurrbo19's Avatar
    Nov 12 2006
    2004 Audi A4 Avant USP
    Middletown, Connecticut
    Does the car sound kinda like a subie? my car turned into a subie just last week and i checked the coils and the plugs they were all fine. turns out that it was the ignition control module. Just ordered one online earlier today and shell be back to running like a champ in 3 days or less when i get the new part
    Apr 01 2007
    Irvine
    Quoted For Truth
    Dec 05 2007
    Autozone will let you use thier scanner for free. You just need to leave a deposit for the scanner and take it home. After you return it, they give you the deposit back.
    May 04 2008
    Columbia, SC
    Replaced coilpacks and she was still skipping like crazy... Swapped out the ICM and voila... Back up and running like a champ. I finally got ahold of my uncle and he said that the majority of the time, cylinder 2 misfires are the ICM, not the coilpack.... he told me to go ahead and swap the coilpacks and see what happens... he was right, no change. Thanks for everyone's help!
    -Nick
    Dec 14 2005
    lol queef??
    Quit Fuckin Talking
    Quit frying turkies
    Quit Fondling Tits?
    quote for truth....
    1999 Subaru Outback
    Nov 12 2006
    what did i tell you...lol
    Sep 01 2005
    would've swore it was the coil-packs. but then again im an 01 so i don't even have the ICM so it didnt even cross my mind. hey but at least you found the problem
