Results 1 to 12 of 12
    Registered Member Two Rings FourBlackRings's Avatar
    Jun 02 2008
    Monrovia, MD
    ECS N75 race valve?????
    i was thinking of getting this for my 98 1.8t giac chipped a4 but it says its only compatible with the tt? will it work on my a4?
    http://www.ecstuning.com/stage/edpd/...l=&engine=1.8T
    there is the link to it. please let me know i have searched and cant find it. my n75 shit out so i need new one and this one is cheaper.
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Re: ECS N75 race valve?????
    I have a GIAC chipped 1.8t and i am running an N75H race valve that i got from 034..... It works awesome, i just wish i had gone with the N75K version
    {99.5 Avant}
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Will work fine on your ndbw. The race valve is just a N75 valve from the old 5 cylinder turbo cars.
    Apr 01 2005
    one wagon one truck
    Michigan
    Whats the difference between K and H?
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    Can i use the N75 valve on my AEB engine? i thought i read something that i couldnt....i gota read up.
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Nov 15 2007
    Audi A4
    Redding, California
    Quote Originally Posted by jaustin View Post
    +1
    Deactivated Four Rings
    Jul 16 2007
    2000 A4 Avant 1.9L BT
    Irvine, CA
    Quote Originally Posted by thenofboy View Post
    We don't recommend it as the cars are prone to overboosting and surging with it (which people will tend to blame the software for, despite the hardware mismatch). Since the nDBW cars do not close throttle like the DBW cars (there is no potential boost mismatch to close the throttle), the throttle will stay open. If you had a nDBW car, without a resistor to clamp the MAP, the car would close throttle due to boost overshoot. This is likely what you read....
    May 22 2008
    az
    They come in a lot of variations indicated by the last letter of the part number (C, F, J, K, H etc) and they differ in how much boost they will hold before opening the wastegate. I think K is the most, but i could be wrong
    {99.5 Avant}
    Jul 16 2007
    Irvine, CA
    Quote Originally Posted by Jibberific View Post
    C,F are OEM 1.8T valves. C was came on the 97-2003 vehicles and was prone to failure. It was superceded with the F valve which is also a stock valve.
    As noted before, the H, J and K are from other vehicles and have stiffer springs in them. I have never tried the K valve, but saw little difference between the H and J in my old car.
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    I run the ECS Race Valve on my nDBW '99 combined with APR 1.0 bar chip with no problems. Boost comes on a little stronger earlier on in the rev range. Spike at 17-18 and holds 15 psi until the KO3 normal drop off at 5K.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Apr 01 2005
    one wagon one truck
    Michigan
    Hmm guess ill shop around for one... And thanks for the info on them.
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    I used the "H" valve for quite a while until just a few days ago. I was hooking up my Boost Machine and when I pulled the valve out of my tip I broke it, what a bitch. I enjoyed it with my APR chip on a 01 and it did increase my boost by about 1 to 2 psi depending on weather. I did feel it pull a little bit harder but who knows I never dynoed it or anything. I had to put my stock "C" valve back in but now I run my boost machine so it doesn't realy matter. The "K" valve is supposed to be a stronger valve and it is the one Dahlback recomends with their K03 program.I don't know anyone who used it so I couldn't say anything about it.
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
