Results 1 to 40 of 54
Thread: Rear deck Bose
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Rear deck Bose
    So my speakers are rattling like crazy and i pulled the rear deck off to examine them and the dust caps are glued on still. there are little spots here and there where it looks like there loose but when i touch them there is no play to the dust caps. If there is the littlest opening would that cause them to rattle... or they could just be blown??
    Sep 25 2006
    01.5 Laser S4 Avant :: 96 VR6 GTI
    Littleton, CO
    Re: Rear deck Bose
    It is VERY common for them to blow....
    Probably have to disconnect them and get new ones or disconnect them and get a line output converter and get an aftermarket sub in the trunk!
    Senior Member Two Rings nvrfollow's Avatar
    Apr 19 2007
    Silver S4 - Laser S4
    Montana
    Re: Rear deck Bose
    Mine were he same way. I peeled the dust caps off and epoxied them back on which seemed to do the trick.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    yeah i tested the speakers with out the dust caps on and they sound amazing. So i am contacting cemeting them back on instead of epoxieing.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    if this doesnt work can you just use the speaker without the dust caps on?
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    Re: Rear deck Bose
    go spend 100 bucks on some polk audio speakers and put em in there, you won't regret it.
    -Luis
    Veteran Member Four Rings will175's Avatar
    Apr 25 2007
    Las Vegas..Hawaii..Nor Cal
    Re: Rear deck Bose
    I got a rattle in my right rear speaker. Going to try and do what you guys suggested about the dust cap, see if that helps.
    Train Hard, Go Hard, But always be Humble.
    Active Member Two Rings kavalaris's Avatar
    Sep 22 2007
    '00 S4
    san mateo
    Re: Rear deck Bose
    Quote Originally Posted by lrg8683 View Post
    do you mean these?
    http://www.polkaudio.com/caraudio/fi...000&trim=11818
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    i have just finished installing the speakers back in and they sound AMAZING!!! like brand new. and the contact cement only costed about $3.50 from home depot. If they blow then maybe il consider the polk but until then i love my bose!!!
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    also when you do it make sure you take the dust cap completely off and clean the glue off then reapply the contact cement and push it on. then once its on and set i went and just glopped glue around the edge of the dust cap and speaker to make sure there was no air passing through and also to make sure it was adhesived properly.
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Re: Rear deck Bose
    pics?
    Join the OhioVW facebook group for gtg, show, and cruise instant updates!
    1998 VW Jetta GLX VR6 | 2001.5 Audi S4 6MT | 1984 VW Jetta GLi | 2004 VW Golf .:R32 | 2001 Audi TT 225 Coupe quattro
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Re: Rear deck Bose
    Quote Originally Posted by 00s4slvr View Post
    Main Entry: ad·he·sive·d
    Pronunciation: ad\-ˈhē-siv, -ziv\, -ed\
    Function: super-superlative adjective
    Date: 2008
    1 : glued down like a mo-fo
    2 : tending to adhere or cause adherence... real good like.
    3 : prepared for adhering'ed
    Also see:
    — ad·he·sive·d·ly redundant adverb
    — ad·he·sive·d·ness over-punctuated noun
    sorry, I couldn't resist
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Veteran Member Four Rings AudiXS4X01's Avatar
    Nov 11 2006
    01 Audi S4-Santorin Blue
    Tri-State
    Re: Rear deck Bose
    ^haha...thats funny, i looked up the word too after I read it...unlike you though, i was able to resist
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    lol sorry for the incorrect usage of the word lol. anyways yeah i didnt take pics... sorry i just followed the other write up and just assumed to use a lot of glue to make sure that there is no air passing through the dust cap. if i get around to it i will take pics of how much glue i used.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    i meant i used a lot of contact cement not glue. DO NOT USE GLUE IT WILL NOT HOLD!!!! I applied a good amount of contact cement to the dust cap and the speaker. Then once i set it in its spot i then reapplied a lot of contact cement around the edges to ensure supreme adhesion!!!
    Nov 11 2006
    Tri-State
    Re: Rear deck Bose
    im gonna have to do this also with my rear right speaker. I did this a couple months ago with super glue, but it didnt hold. I'll have to try contact cement.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    yeah supposedly the contact cement is supposed to be a permanent fix.
    Established Member Two Rings 2k1.5blacks4's Avatar
    Jul 02 2007
    2001.5 s4
    Birmingham, Alabama
    Re: Rear deck Bose
    leave the dust cap off weight reduction mod
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    lol you cant be serious. that thing weights like less than a gram lol
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    Re: Rear deck Bose
    how did you guys remove the rear speakers is there a DIY?
    10 b8 s4 6MT sprint blue / black & silver
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    yes there is a diy, i think i searched rear deck and it came up, but anyways its very easy.
    step 1: Fold seats down.
    Step 2: pop those 3 black caps off on the rear deck and remove the bolts.
    Step 3: pop up the front of the rear deck.
    Step 4: slide rear deck towards you and be careful not to scratch the speakers with the 3 black clips.
    to reinstall do it in the reverse order. I will try to look for the diy and post.
    Nov 11 2006
    Tri-State
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    here is the diy.
    http://forums.audiworld.com/s4/msgs/1760180.phtml
    it took a total of about 45 mins to take the rear deck off, contact cement the dust caps back on to the speakers, and then reinstall the rear deck.
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Re: Rear deck Bose
    I just remembered I need to do this too. Thanks!
    Apr 25 2007
    Re: Rear deck Bose
    Just took the rear panel off but I still need to buy contact cement. Its not that hard to take everything out, just take your time.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    yeah it is pretty easy but just take your time so you dont break anything. Also for the contact cement go to home depot in the painting section and the company is called Dap welwood who makes the contact cement that i used. WORKS LIKE A CHARM!!!
    Nov 07 2007
    New York City
    Re: Rear deck Bose
    thanks for the help
    Nov 02 2005
    S4
    VA
    Re: Rear deck Bose
    -Luis
    Veteran Member Three Rings mikeyvuitton's Avatar
    Mar 26 2007
    Denver
    Re: Rear deck Bose
    Alpine type R components ftw
    2005 S4 6SPD: Bagged, Rotiform, Bamboo, Hermes.
    Project Hoodrat: B5 RS4 Widebody/GT3071r
    Bruiser Brigade
    Apr 25 2007
    Re: Rear deck Bose
    Just cemented mine its better then it has been for a long time and it was basically free.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    and its supposed to be a permanent fix so hopefully it is. Anyways hope you like the new sound!!
    Veteran Member Four Rings Bimmerchop's Avatar
    Aug 23 2004
    2000 BMW 328i
    Re: Rear deck Bose
    I gotta try this
    Rich | 2001.5 EPL stg III+ TiAL 605.2 Pearl White S4 | Flickr
    EPL | ER | SDR | APR | Stratmosphere | 034 | ASP | SPEC | Fidanza | STaSIS | H-Sport | AWE | H&R | StopTech | Fikse
    Sep 22 2007
    '00 S4
    san mateo
    Re: Rear deck Bose
    oh, okay. are those a direct fit that i could install myself?
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Re: Rear deck Bose
    If those are direct fit then I'll be getting them. I tried gluing mine and they still rattle.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    if you glued them and make sure that there is no air passing through and they still rattle then chances are you blew them! :)
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    actually that sucks sorry :(
    Apr 17 2007
    B8 A5
    Re: Rear deck Bose
    I just did this last night. It was so freaking easy.
    I've taken some pics to show the process and what you should do. I know, I'm no artist, and my glue applying skills are teh suck.
    Close up of the old glue around the dust cover.
    Picture of the first speaker with the glue removed.
    Dust cover removed.
    Both dust covers removed.
    My awesome glue applying skills.
    Both applied with glue.
    Finished product.
    It ain't pretty, but these mofos will hold out forever!
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    Nice job. Mine was like that just more glue lol
    Veteran Member Three Rings B501S4's Avatar
    Sep 09 2007
    01.5 B5S4 Stg III RS6's Built Longblock, Cherokee Classic 4x4
    Raleigh, NC
    Re: Rear deck Bose
    might have to do the same my right rear has been rattling
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Rear deck Bose
    try it and if it doesnt work then pretty much youve blown your speaker.
