Thread: Help with part?
    Senior Member Three Rings theboogieman1's Avatar
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Help with part?
    I popped my hood tonight with the car idling and noticed a loud hissing sound, with a little searching came across this vac line or something that had snapped:
    Does anyone know what this is called? As a reference, my boost gauge hose is just behind the broken part. I'm hoping to pick up that part at the dealership first thing in the morning so I can get this installed this weekend. I think it's the reason for my high idling lately. I don't have time to search this out so any quick help would be appreciated. Thanks!
    02' Black S4 6spd / JHM "Stage 3" / JHM "Solid" Shifter / VAST Stg. 3 Clutch and LW Flywheel / Vogtland GT's / 034 Track Density Motor Mounts/ AWE DTS / JHM FMIC / Hawk HPS Pads / H-sport sways / SSAutochrome TB Exhaust
    Veteran Member Three Rings SilverBiturboS4's Avatar
    Sep 14 2006
    Dallas,tx
    Re: Help with part?
    That is called a Check Valve. I broke mines a couple of years ago too. its cost like 20 bucks at the dealer.
    2001.5 S4
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: Help with part?
    pick up some new braided vac lines as yours appear to be dry rotted.
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Re: Help with part?
    Great, thanks guys. Glad it's something cheap for a change
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Re: Help with part?
    So funny thing just happened. I was just about to post that I checked all my lines under the car and all looked good, but as I was looking at the pic I posted, something didn't look right. Sure enough, the local shop I had put this in installed it backwards. I'm assuming that's were this vacuum code is coming from. So I just flipped it around and I guess I'll find out in a couple days if this code comes back. Thanks for all the help.
