2003 Porsche 996 Twin Turbo with 550 hp at the flywheel.
Wheels, Wells & Tires
P21s Wheel Gel Cleaner
Meguiars APC +
Meguiars Wheel Brightener
Smart Wax RIM WAX to seal wheels
Various Brushes and Foam Swabs
Zaino Z16 Tire Gloss
Exterior Wash
P21S Total Auto Wash
Chemical Guys Citrus Wash & Gloss
Clay
Chemical Guys Blue Clay
Finish Kare 4125 Quick Detailer used as Clay Lube
Paint Correction
LC Purple Foamed Wool with Menz SIP
LC Orange Pad with Menz SIP
LC White Pad with Menz PO106FF
Trim
Black Wow
303 Aerospace Protectant
Prima Clarity Glass Cleaner
Glass Polishing Cloth
Meguiars NXT All Metal Polish
LSP
3 layers of Zaino Z5 Pro with ZFX
Z8 Grande Finale between layers and final wipedown
Equipment
Karcher Electric Pressure Washer
Cam Spray Foam Cannon
Makita 9227c
Porter Cable 7424
LC 6.5" pads & 4" pads
Befores
The owner was gracious enough to help with the removal of the wheels to thoroughly
clean them and the wheel wells. He also volunteered to do the interior since it was in very good condition to begin with.
Using foam tipped swabs to clean all the crevices.
Since we only had two jacks, the wheels were removed 2 at a time.
P21S Gel cleaner didn't cut through the baked on brake dust too well so Meguiars Wheel Brightener was used and it did the trick. It was also clayed to remove stubborn spots.
After P21S TAW pre-soak, car was foamed with CG CWG.
Car was clayed about 6 months prior so it did not have very much bonded contaminanats.
