Results 1 to 9 of 9
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    Boring engine - DMV reqs?
    I read a lot about boring out the engine from 1.8 to 1.9/2.0, but I was just wondering, since you have changed a major component of the car, do you have to contact and tell the DMV this so they can input it into their database? Cause I would imagine that if you needed to get the car smogged, their database would expect either a 1.8T or 2.8, not a 1.9/2.0 in a b5 a4?
    Moose
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: Boring engine - DMV reqs?
    nope, dmv will never know ;) They have noway of knowin you motor size, especially since its all internal
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Feb 15 2008
    Sacramento, CA
    Sweet. I have so many freaking ideas running through my head it hurts. The only thing is smog, since increasing bore size I'll probably be increasing my fuel usage which in turn makes my car emit more and so on and so forth, will it become more difficult to pass smog? Obviously make some tweeks to the exhaust to get the flow better, but will I have to tweek it more than if I left it 1.8 with a hf cat?
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    if you are going to be spending that much money to bore your engine out, why even care about the DMV? I run full test pipe setup on my car (no cat) with a fully built engine and have no problems at all. now if i was to get smog tested I wouldn't make it in the testing building before failing :)
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Veteran Member Four Rings SoFresh's Avatar
    Mar 15 2006
    Seduction Motorsports 1955 Porsche 550 Spyder, Porsche 356 Coupe
    Scottsdale - Palm Springs
    3" turboback exhaust here, no cats either... then again, I dont have to do emissions where I live
    Production Manager - Gunther Werks
    Founder - Seduction Motorsports
    Feb 15 2008
    Sacramento, CA
    haha, normally I wouldn't care, but what's the point of doing it if I need to use it as a DD, but can't because it won't pass smog? Which is why I brought up the question. Now, if I was to make it a track car, then I wouldn't care, and the only way that would happen is if I buy the 1986 Porsche 944 I'm gonna be checking out withing a day or 2 since my audi is currently inoperable.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by Mooseimage View Post
    Yes you will use more fuel but your AFR will not change and that is all that matters. People have been doing bore/stroke on the 1.8t for over 6 years.
    You might be thinking way to much which is why your head hurts.
    Feb 15 2008
    Sacramento, CA
    Cool, so as long as the AFR is right, I'm gonna be good. Now that my head hurts slightly less, I can find another thought to replace it with.
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    Quote Originally Posted by SoFresh View Post
    how do you get away with no emissions? my truck passes a sniffer dyno test with no cat :)
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
