Results 1 to 14 of 14
Thread: How low?
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    How low?
    I have 18x8.5" BBS CH wheels with 235/40/18 tires on a B6 3.0 Quattro A4. How low can I drop the car without running into any issues? Thanks in advance.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: How low?
    pretty low
    -Sami-
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: How low?
    Quote Originally Posted by 4Rings3Liters View Post
    Very low, I assure you.
    18x8.5 CH's are usually et32, so it's a moderately aggressive fitment. If you want to lower the car a lot, make sure to remove the bolt at the top of the front fenders (12 o'clock position, feel for it just inside the fender, remove the bolt and cut the plastic tab off, you'll never know the difference and the car won't rub). You can go pretty damn low no prob, but you may rub occasionally over big bumps or while corning really hard.
    -Darrick
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Re: How low?
    Quote Originally Posted by Capt. Obvious View Post
    I think they are actually et35, but yes you shouldn't have any problems going low.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Jul 04 2008
    York, PA
    Re: How low?
    They are ET35. Would 2" be too low?
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Re: How low?
    Roll your fenders too
    Jul 04 2008
    York, PA
    Re: How low?
    What's the bolt for?
    Jun 13 2005
    Audi
    Re: How low?
    Holds up the fender liner. It stays up fine without it though.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Jul 04 2008
    York, PA
    Re: How low?
    So does anyone know if a 2" drop will cause problems?
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    Re: How low?
    whatever you do. please post a pic after youve lowered it. im dying to see what an 18 inch ch looks like on a lowered b6.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Jul 04 2008
    York, PA
    Re: How low?
    I sure will.
    Veteran Member Three Rings HamidsVikes's Avatar
    Jan 10 2008
    Vancouver, BC
    Re: How low?
    I have the same set up...
    I have H&R sprinks in there and aftermarket shocks...
    I have had no problems with how low she is, and infact she could go much lower... but I am running 19's
    here is a pic...
    Jul 04 2008
    York, PA
    Re: How low?
    I got Neuspeed Race Springs which advertise as being a 2" drop in the front and rear. Hopefully that isn't a problem.
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    Re: How low?
    neuspeed springs will probably end up going lower after they settle after a few days
