    Veteran Member Three Rings rAphb0y's Avatar
    Jun 21 2008
    Boston
    cars a little shaky when on .. ?
    could it be a vaccum connector? or something else?
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: cars a little shaky when on .. ?
    Gonna need some more detail. Does this occur in gear? Does it occur when at idle? etc etc
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 13 2008
    Western Chicago Burbs
    mine does the same thing too when im in gear. the whole car vibrates but if i put it in neutral or reverse it stops the shaking.
    Jun 21 2008
    Boston
    my car all of a sudden started nd shut right off when i tried to give a little gas so come to find out i needed a new ECU .. got it installed today and check engine light comes on giving out a code i believe either P1626 or just 1626 one of them which im not sure what they are .. took it for a ride around the block .. let it run for an hour nd everything seemed to be fine until i drove it home and i noticed when idle its shaky .. then i put 1st gear nd take off its fine .. when switch to 2nd it doesn't give as much power as it used to .. any ideas ?
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by B6JoeA4 View Post
    My car did the same for a while and still does it slightly. First thing to do is to check for all vac leaks. Once i replaced my MAF sensor, this went away.
    My 5-Speed Swap DIY
    - B6 USP
