Results 1 to 3 of 3
    Alcon Brakes installed on customer's Audi RS6!
    One look says it all - high performance, ultra-refined technology and style with massive gripping power. Nothing screams from behind the spokes like an Alcon-based braking system from STaSIS.
    What It will do for you:
    NO MORE FADE
    Higher heat absorption and dispersion makes for shorter stops turn after turn
    IMPROVED PEDAL FEEL
    Firm, confidence-inspiring brake pedal because of ultra-stiff calipers, differential piston sizing and stainless steel braided lines.
    SAY NO TO WARPED ROTORS
    Properly Designed 2-Piece Floating Rotors = Quiet, warp-free performance
    QUICKER REACTION TIME
    Short, consistent pedal travel can save your life in a panic situation
    SHED THE POUNDS
    Less weight gives shorter stops, quicker acceleration, improved steering feel and handling
    LOWER LONGTERM MAINTENANCE COSTS
    Cutting edge design = durable, low-cost system
    COMPATIBILITY & EASE OF INSTALLATION
    Compatible with ABS and traction control systems with brake bias designed to ensure ultimate gripping power. All hardware is included to ensure a quick and seamless installation.
    What's In the Kit:
    ----ALCON 6 Piston Monobloc Calipers (Silver only)
    ----ALCON 370mm(14.5") Floating Rotors
    ----STaSIS Caliper Mounting Bracket & Hardware
    ----Goodridge Stainless Steel Braided Lines
    ----Motul brake fluid
    ----SBS Hi Performance Brake Pads
    You can view all of our Alcon products HERE
    Veteran Member Three Rings LA_AudiTR's Avatar
    Oct 16 2004
    Cadillac Escalade
    SoCAL now in NORCAL
    Re: Alcon Brakes installed on customer's Audi RS6!
    those are looking sweet!!!
    I would have highly considered those if i didnt already have a set on my S6!!!
    Quote Originally Posted by vividracing View Post
    NO MORE FADE
    IMPROVED PEDAL FEEL
    SHED THE POUNDS
    What's In the Kit:
    Current: 2014 Cadillac CTS-V Black Raven Wagon 556hp of pure blisssss
    SOLD: 2002 S6 AVANT
    FORMER: 2003 A4 1.8TQ 5M MODS: APR Stage 3+ (thats all that matters) - she will be missed ...
    Established Member Two Rings TimTaylor's Avatar
    May 03 2008
    Colorado
    They look good and sounds like they are quite an improvement.
    Could be a possibility for my RS
    15 Huracan - ADV1/Famous/Novitec, 13 S7 - APR/Milltek, 11 R8 V10 Spider - Hanksville Xpipe, 07 599GTB Capristo/Novitec/H&R/ADV1, 06 F430 - Tubi/Fabspeed, 15 AM Vantage GT, 16 Z06, 12 C4S, 12 RR Autobiography, 95 GSX-Full built
