3 Faults Found:
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 25
Mileage: 65019 km
Time Indication: 0
Freeze Frame:
RPM: 4786 /min
Load: 98.0 %
Speed: 102.0 km/h
Temperature: 99.0°C
Temperature: 48.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.716 V
012599 - Intake Manifold Runner Control: Basic Setting not Completed
P3137 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 66596 km
Time Indication: 0
Freeze Frame:
RPM: 264 /min
Load: 67.4 %
Speed: 0.0 km/h
Temperature: 55.0°C
Temperature: 47.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 11.176 V
008196 - Intake Manifold Flap; Bank 1: Stuck Open
P2004 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 66601 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 92.0°C
Temperature: 36.0°C
Voltage: 12.954 V
Readiness: 0000 0001
i did a data log 3rd gear 1900rpm till redline but not sure if i recorded it correct. ill try to post that up as well. tia pete
