Originally Posted by
HotRod1200
did you encounter a lot of problems after purchasing a stage 3 S4???
Well in my two months of owning the car here's whats broken or gone wrong:
Valve cover leaking (fixed)
Cam seal leaking (to be fixed)
Rear brake pads changed (no big deal)
Throw out bearing broke into pieces (transmission had to be pulled to replace it)
The rack is leaking, needs to be replaced
Front dampers were blown (fixed)
Some of it is my fault for not catching it before buying the car - so like I said, have the car looked at.
But that being said, I bought a one owner car, with only 69K on it - all work was done at AWE tuning - and I have all receipts to prove it.
When the valve cover was off, the inside of the car was so clean it looked like the previous owner changed the oil ever 500 miles.
When the trans was out to replace the TOB, the flywheel looked so clean. There were NO hotspots on the flywheel, it was NEVER launched or abused.
Buying a modded car is buying someone elses problem - just make sure you know what problems you are buying. Good luck.
