Results 1 to 4 of 4
    Aug 09 2005
    Ottawa, Canada
    FORGE 004 install help
    Hi all, i've got a 08 2.0t and want to install my forge 004.
    My question and I did search but came up with nothing is, what do I do with the computer controlled DV valve once I install this thing. Does that become unplugged, do I leave it plugged in...etc....I guess a step by step of where to install this thing from others who have the same motor and the ECU controlled OEM DV would help alot right now.
    Thanks in advance
    08 A4 2.0T SLine 6speed -eibach prokit, rs4 sway, intake blah blah
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    Re: FORGE 004 install help
    ummm forge 004 does not fit the 2.0t engine....that's for hte 1.8t engine completely different
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    yeah it won't work!
    The usual things!!
    Resistor Install
    DUH! an Audi
    los angeles, CA
    will not fit! sadly =x
