Results 1 to 19 of 19
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Going to see a lot of me around...
    This week I'm picking up a 2000 A6, bone stock with 140k on it. The car itself is in really good shape, and not destined to stay stock for long.
    A little about me. I can't leave cars alone. I currently have a 2003 Dodge SRT-4 I bought new 5-1/2 years ago. There's almost nothing left stock on it, and it's a blast to drive. However, 450 whp is fairly useless on the street in a fwd, it's a little loud for longer trips with my family, and I need something new to play with.
    That brings me here. I'm picking up a 2.7 bi-turbo 6-speed to start working on. I do all my own work on my other car, but have no experience with Audi's, although working on my wife's tdi Beetle has caused me to curse German engineers more than once.
    A few things I need to do right off the bat: Suspension, brakes, headlight.
    The car is still somehow on the stock struts, so after researching a little, I'm planning on going with the Koni/Eibach combo. I've run that setup on other cars before with few issues. After reading some threads, I'm also going to look at Febi control arms.
    Brakes: I'm dropping a lot in this car right away, so will probably stay away from a full brake kit for now. Any good recommendations for pads/rotors? I've used Hawk pads successfully, but on lighter cars. Also, it looks like Vivid Motorsports sells kits, and they're local to me.
    Headlight: The passenger side headlight is badly fogged. Are there any options other than a new factory one?
    Thanks for any input, I'm an incessant collector of information, and will likely be asking a lot of questions.
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: Going to see a lot of me around...
    it's either here or on audiworld i think, there is a DIY on how to properly sand & polish the foggy headlights to look like new... i may give it a shot this weekend along with a full detail
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    welcome aboard. lets see some pics so we can see this before you start your transformation!
    for brakes, i couldnt give u too much advise, i have seen people use slotted rotors running ceramic pads, SS brakelines, and racing brake fluid (motul i think?) and say it works real well since our stock brakes are more then enough for street use.
    are your head lights stock with HID's? if they are, there isnt many options and almost everyone just clears out the amber piece and call it a day. some paint the housing black aswell. you could look into Allroad headlights aswell, they are nice and bolt right in. think they require HID's though. you could also be our test pilot and try these out if you dont have HIDs clicky. im curious how they will look, i think they would look sweet to be honest (theres a b5 with similar lights in that post)
    good luck
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    I do believe it has the HID's, but I'll have to check. I looked the car over yesterday, and will hopefully pick it up early next week.
    FWIW, this is my current car:
    Mar 22 2005
    Kitchener, Ontario
    thats a clean srt 4. did you do a single side exhaust conversion? i see that done alot on high HP srts
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    I use my back seat (2 little boys), so I passed on the side-exit. Plus it's a bit loud for me.
    I have a 3" turbo-back, single tip exhaust with a muffler. And thanks for the compliment on my car. :)
    Hopefully I can end up with as fun, fast, and clean an A6.
    Mar 22 2005
    Kitchener, Ontario
    im sure you will. if you do suspension, you may want to look at swaybars too. best bang for your buck handling mod you could possibly do. night and day difference how the car responds. h-sports are the best way to go. they are one of the cheapest and you get front and rear
    H&R: front - 275.00 rear 225.00
    Hotchkis, front and rear - 392.00
    edit: for the srts exhaust, didnt mean side exit, meant just 1 muffler in the back, since i think stock they came dual. but i think you did convert to the single exhaust judging from your post
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    first thing I'm going to be doing to the A6, other than brakes & suspension, it pulling the engine to do the turbos, timing belt, water pump, and clutch.
    I'd like a good 400 whp, so I'm researching the RS4K04's, RS6's, and hybrids right now.
    Veteran Member Four Rings VJ's A6's Avatar
    Jan 23 2007
    2000 TL; 2002 GMC 1500 Pickup
    Welcome to AZ..
    Check out classifieds for suspension. I saw some Koni/Eibach for sale.
    I agree with audirs said get sway bars makes a huge difference to the car. I got mine couple of days ago and its worth every penny.
    APR Stage 2
    -Koni's / H&R Sport -Hotchkis Sway Bar F+ R - 2.5 Inch Custom DP's - 2.5 Inch Magnaflow Exhaust -LED Tail Lights -S6 Door Blades -Valentine V1 -35 % Tints All Around
    Mar 22 2005
    Kitchener, Ontario
    youll find alot of info on alot of different setups on teh b5 s4 forum for sure. you can do rs4 ko4s without a proper fueling kit if i remember correctly, and you can get a stage 3- tune which is meant for no fueling. i think giac is the only company that does that if im not mistaken
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    I'll definately be doing a fueling setup as well. I'm waiting until I decide on a turbo before figuring out exactly what I'll need.
    It's interesting coming into a platform where all the turbo upgrades seem to be sold as complete "kits", with a canned tune.
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    sway bars for sure -- combo with Eibachs will surprise you, the Quattro handling is so good, and no roll makes it incredible for larger car; lots of Koni fans here, but I chose Bilstein sports.
    I have headlight issue also -- what do you have in mind?
    welcome,
    wofman
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Not sure yet what to do about that headlight. I was looking around to see if there were any decent aftermarket lights. Barring that, looks like I'll be wet-sanding and polishing it to remove the haze.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Welcome. I see used headlights going on Ebay for cheap all the time. I would check there.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Apr 01 2008
    2010 Jetta TDI
    No aftermarket alternatives to speak of. Can't buy lens without buying housing (Please, somebody prove me wrong!) and OEM prices are ludicrous. Endee666 has blacked out housings available (not lens) that might work with silver (he upgraded to Allroad bi-xenons).
    Stampy - been watching like a hawk -- none available on ebay except halogens, cheap imitations, upgrade kits, or one side but not other type offers for used.
    I'm having sanding/cleaning experiment done on mine in a few days.
    Nov 19 2005
    Pair of (. )( .)
    I think we might have some aftermarket Headlights other then allroad, check the A6 forum, Fanky posted some interesting Sh1t :)
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Apr 01 2008
    2010 Jetta TDI
    well, the LED part is interesting, I'll grant that. I'm looking for xenon. Actually, if somebody (Hella) would sell replacement lenses only they could make a killing! People would pay couple hundred for new pair that costs $20 to produce!
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Well, the deal has been agreed upon, and I'll be picking up my A6 on Thursday!
    Taking advantage of the last day of Purems.com's summer savings, I ordered a full set of front control arms, a set of Koni FSB struts, H&R springs, and H-sport sways. Can't wait!
    Apr 01 2008
    2010 Jetta TDI
    what happened to the Eibachs you spec'd?
